Current Time: 3:12 PM
ZK-TR90 resin and my chambers!
Discussion in 'General Woodworking Discussion' started by Jon Kennedy, Feb 20, 2013.
  1. Offline
    Jon Kennedy
    Jon Kennedy Junior Member
    343
    83
    Spicer, Minnesota
    Jon
    For all the Guys that have bought my products, resin and chambers! I want to hear what you think and how it works!!!:yipee::yipee:
    Jon
  2. Offline
    RusDemka
    RusDemka Thinks he can woodwork,,, sometimes Full Member
    653
    31
    eagan, mn
    dema
    I have the video, just need to crop and.clip it and upload to YouTube
  3. Offline
    camoboy91
    camoboy91 Member Full Member
    44
    0
    Georgia
    Zachary
    Just ordered my second gallon, love this stuff. I would not use any thing else! As far as the chambers, I have not used one (yet) :lol:
  4. Offline
    TimR
    TimR Sawdust Engineer Full Member
    896
    267
    Charlotte, NC
    Jon,
    I've gone thru about 2/3 of a gallon, treated primarily buckeye burl plus some sweet spalted ringer birch. Couldn't be happier with results. :yipee: Thickest piece was buckeye burl block about 2x2x6, give or take. I have a friend who does segment work who will be cutting into some of the larger BEB blocks, but I expect they will be completely stabilized judging by weight difference alone. I am pretty sure specific gravity on these has gone past 1...or close to it. Will have to see if they have any float left. :wacko1:
    Only thing I've done is a couple pens, but was really pleased with results.
    I do suggest to anyone using a toaster oven or even conventional to use a thermometer to verify temp...which was about 50 deg hotter than actual.
    I'm using the dry method, but even after introducing the resin, and having pulled vacuum for half to whole hour, still get out gassing. Could be residual moisture boiling out. My stock is kiln dried, but then sitting in shop easily rise to perhaps 8-10 % MC.
    Likewise...I'll be getting more.
  5. Offline
    RusDemka
    653
    31
    eagan, mn
    dema
    http://www.youtube.com/watch?v=t3GBCtWdc7c&feature=youtube_gdata_player
  6. Offline
    hobbit-hut
    hobbit-hut Don't leave home without it. Full Member
    1,597
    253
    sarasota fl
    lowell
    Excellent video, good job, thanks for doing that. I think it will get a lot of viewing. I may need to get you autograph now before you get famous.:way2go::good:
  7. Offline
    woodtickgreg scroll, flat, spin Staff Member Forum Moderator Founding Member Full Member
    5,771
    1,117
    clinton township, mi. usa
    Nice video, it's one thing to read about a process or a product, but it really is better to see something being done. Thanks for doing this video.:good::good2:
  8. Offline
    RusDemka
    653
    31
    eagan, mn
    dema
    Your welcome guys.
  9. Offline
    Wildthings
    Wildthings Member Full Member
    1,304
    242
    Gulf Coast of Texas
    Yes I agree with them that the video review was well done - Thanks
  10. Offline
    jetcn1
    jetcn1 Member Full Member
    134
    25
    S. E. Mn
    Troy
    Hey I have just a couple of comments on your very good video. You should leave your pump running when you release the vacuum to keep your pump from locking up under vacuum. Also you should use a oven thermometer to make sure of your cure temp. I have learned these lessons from the 4 years I have been stabiliziing . Jon has some great chambers and resin. I was lucky enough to be a tester of this resin when Jon was developing it . The ZK TR90 resin is the best out there . Troy
  11. Offline
    RusDemka
    653
    31
    eagan, mn
    dema
    Running it while releasing the vacuume explains a lot.... Because mine did lock up a couple times and I didn't know why, thanks. And I did get a thermometer just can't see it in the video :). Thanks for the input, I'm still new at stabilizing..
Share This Page
