• A New Photo Gallery Has Been Added!!! Please share pictures of your finished projects in the New Photo Gallery for everyone to enjoy browsing. This section is for FINISHED PROJECTS ONLY!! All others will be deleted. This section was created to give people a place to view photos without having to read through all the threads. Enjoy everyone and please contribute!
1/16" thick Mesquite plate
Nubsnstubs
Where is it???
Tucson, Arizona
Jerry
Yesterday, I was finishing up on a 18 small plates for a friend that is donating them to one of our local schools. They are going to be commemorative plates for students who have outstanding achievements in the community or the school. The tree that I made these from is Aleppo Pine that grew on the school grounds and finally fell in one of our Monsoons a few years back.
When I needed to sand the bottoms before finish, I found this piece of Mesquite that was just over 8" OD, and about 1 1/4" thick that already had a tenon from a year ago. I had to glue up some cracks then, and after glue, it was set aside in the black hole of my shop.
I measured the diameter of the Pine plates, and proceeded to turn a depression in the face of this Mesquite to fit the smallest plate first, and then made adjustments as I progressed until all were done. I have no pictures of this method, but when done, I decided to make a plate out of the Mesquite.
While turning this Mesquite plate, I decided to see just how far I could take down to. When I got down to just over 1/16" thick, I started sanding it with my ROS. That is when I heard it crack. Stopped and checked it out. There was a crack leading from the rim to about 1" into the plate. I got some CA, and made my repair. After it cured, I started sanding again. It cracked again, 180 degrees from the first crack. I fixed that one too.
I then figured it was thin enough and time to remove the tenon. I set up a friction plate, and proceeded to remove the tenon . When I got down to about a 3/4" nub, I heard it crack again. Had to stop and make the repair, and went back to tenon removal. Another crack and I took the piece off to make another repair. It sat on my desk all night to cure and I decided to remove the rest of the tenon/nub in the morning.
This morning came, and I grabbed my piece to go out into the shop. At the door, I had the plate in one hand, something in the other and was trying to get the door open. I then put the plate between my body and arm, and used that hand to get the door open. The second I moved my arm, the plate hit the floor. Well, shucks, broken again. I looked and found only one crack. Got it glued, and was about ready to mount it when I saw another crack. Damn, this poor plate has 3 cracks in 2 places all within a 1" spot. But, after the repairs, it's still solid. Because of the thinness, it's pretty flexible though. Anyway, I'm going out again in about 10 minutes to finish the nub removal.
OH, crap, I just found another crack......Here are pictures I took about an hour ago before finding this last crack.
I am gonna finish this piece as it it absolutely the thinnest piece I've ever finished, I hope. Finished piece in about 30 minutes.
The second picture shows a piece under the plate. It's Mesquite that will be an Olla resembling some of the pottery that has been found in archeological sites here in the Southwest. I was hollowing pretty good until my tenon broke. That's in repair too.............. Jerry (in Tucson)
Nubsnstubs
Where is it???
Tucson, Arizona
Jerry
Done!!!!!! It wasn't that easy. No problems with removing the nub. My problem is this piece was videoed from start to finish. When I turned on the camera this afternoon, I decided to demo how I dropped and broke it this morning going out the door. Not a good move....... When I positioned the camera, I brought up the piece to show how I had it under my arm. I hit the Tail Stock wheel, and knocked out a piece about 1 1/4 x 3". Man, this poor plate has had it share of mishaps, but it's a survivor. I manage to get the glue in and put it back together, then went ahead and removed the nub. I'm gave this plate 7 Purple Hearts for it's battle with me. When taken off the lathe, it weighed 49 grams, but with the Lacquer it now weighs 53 grams. It's 7 7/8 diameter with 1/16 rim. The foot is 3/32 thick. The rest is all 1/16"...................Jerry (in Tucson) 85D248D0-DEC0-474F-A9BE-A46DC6505547_1_201_a.jpeg 99964840-463C-4B76-926D-DC3DD4DDD6DD_1_201_a.jpeg 725DE262-99F8-42C2-B229-FC7DF0F7149B_1_201_a.jpeg BBC1944C-9C23-4CFA-A5F1-0A89D66EE489_1_201_a.jpeg D8977A68-2483-4278-B8D6-BDA4BE7FEF21.jpeg
Nubsnstubs
Where is it???
Tucson, Arizona
Jerry
Weight 49 grams? That's Metric Jerry, HeHe,HeHe.
Rgds,
Crocy.
You're right Croc, but when all you have is a gram scale that was used to weigh illegal drugs, you gotta go with the readings. In case you haven't figured it out, that 49 grams equals 1.72842414 ounces.
I'm glad to see you're still active. Take care, buddy. ......... Jerry (in Tucson)
Nature Man
Redding, CA
Congrats for your determination on completing this piece! You conquered where others would have thrown it in the burn pile! And it turned out nice in the end! Chuck
chippin-in
Houston, Texas
Robert
Nice work and kudos on determination. I have a couple in the shop that I one day want to try and finish, especially since you just made me feel like a quitter :cry2:
Robert
Nubsnstubs
Where is it???
Tucson, Arizona
Jerry
Robert, don't call yourself a quitter. A better term, and it's being coined as I write it out, "You are a set asider." I usually set something aside until I'm ready to either complete it, or destroy it. I do love those type of challenges. ............... Jerry (in Tucson)
