1911 Grip Making Question
Discussion in 'Grip and Stock Makers' started by Dmcoffman, Dec 8, 2019.
  1. Dmcoffman
    Dmcoffman Member Full Member Thread Starter
    58
    20
    Tn
    Don
    I've started making a few sets of 1911 grips for my use, on occasion I’ve had to pitch a panel due to slight misalignment of mounting holes; currently, I use a known good grip as pattern clamped to my new panel and transfer punch the centers and drill using a countersink bit. As you know with mounting the slightest error is monumental.
    I’m to the point of buying a drilling jig or having one made. If I may ask - what do you use to minimize -or- eliminate this problem?
  2. Nature Man
    Nature Man Member Full Member
    7,374
    983
    Redding, CA
  3. ripjack13
    ripjack13 ɹǝʇɹɐqpooʍ Staff Member Administrator Global Moderator Forum Moderator
    25,351
    6,714
    • Useful Useful x 1
  4. ripjack13
    25,351
    6,714
    For the drill bits, I ues pointed ones so they don't wander. I use my drill press and an xy vise. Start it a little at a time to get the point in the correct spot. Then drill it slowly....
  5. Dmcoffman
    58
    20
    Tn
    Don
    Got the special bit, I really like the drill jig, .
  6. ripjack13
    25,351
    6,714
    This is the set of bits I have and use. They work great. and never wander.
    link to amazon
    • Useful Useful x 1
  7. Customgripper
    Customgripper Member Full Member
    504
    199
    Tennessee
    Curt
    Hey Don, I simply afix the pattern for the size I'm going to make and use a 1/4" center punch to mark ther locations then, use a very small bit (3/64") to drill a pilot hole based on that initial punch mark. Then, you can start drilling the size hole you need guided by that small pilot hole.
  8. Dmcoffman
    58
    20
    Tn
    Don
    Thx for the reply Curt. I bought a set of transfer punches and started using the 15/64th's thru a good set of grips, but don't want to continue with a grip. Appears I'll need to get someone with a mill to locate a couple holes for drill bushings and be done with.
  9. Customgripper
    504
    199
    Tennessee
    Curt
    Okay Don, let me know what you come up with and how it works out for you.
Current Time: 5:30 AM
