Best finish for Big Leaf Maple
larry C
Elberta, Alabama
Larry
Guys, I'm turning a bowl from a fantastic BLM burl that I bought about a year ago.....I've never turned BLM, or worked with it in the past. I have used a lot of soft maple over the years, and usually finished it with lacquer, either brushed on or sprayed.
I don't want to stain or dye this burl, and at this point, I don't want to screw it up.....any advice on the best finish to use will be appreciated.
Thanks,
Larry
barry richardson
I've turned a couple of pieces from it and used lacquer, I was very happy with the results. If the wood is soft or punky, an oil finish can tend to really darken those areas...
larry C
Elberta, Alabama
Larry
Pictures or what burl??? :lol2::thanx2::unknown::impatient:
When I get this one a bit further long, I'll post pictures...
I agree with the statement that oil finishes will darken the punky and end grain areas.......I don't use oil much anymore....When I had my shop in Indiana, I sprayed a lot of lacquer, both regular and catalyzed. Its hard to beat, and easy to repair when damaged..
rocky1
Way North Florida
Rocky
MinWax Polycrylic would be my "Go To" if I didn't want to darken it, it typically does not darken anything. Applied it to small Redwood Burl bowl I was working on recently and had to go back and wet sand with BLO to bring the figure out.
Have found it to be an excellent finish otherwise, very tough when completely cured.
larry C
Elberta, Alabama
Larry
I use bowl I was working on recently and had to go back and wet sand with BLO to bring the figure out.
I use Polycrylic on a lot of the furniture I build, especially, the tops......it's the first waterbased finish I've ever been sold on....it't nearly as hard as a catalyzed lacquer.....
17 years ago, I built a dining table, with a rosewood top. I finished it with Polycrylic, brushed on, and applied 12 coats, I used the satin.....then wet sanded to 600 grit,
then rubbed that out with dry newspaper......it turned out beautiful! I told Jacquie not to "baby" this finish, but use it......we've spill water, soup, you name it, and other
than an occasional newspaper rub out, no problems.
The only thing that messes it up will be from laying a leaking flashlight battery on it.....I'm speaking from experience! It can be repaired, but it can be a challenge...
Mike1950
Beautiful!
Thanks, I am a one trick pony when it comes to finish anymore. General WOP. biggest mistake with bigleaf is not sand enough in beginning to get the little-pits-chip out Or ? sanded out. do that on coarse grits and it is easy to get nice finish.
larry C
Elberta, Alabama
Larry
I started at 80 grit Abralon, and went through the grits all the way up to 1000.....mirror finish, and look's good with gloss lacquer on the outside......will be starting to hollow the inside
today or tomorrow.....the little pits are a challenge, but then so is life sometimes :givebeer:
Mike1950
On burl I cheat on the little pits- eye holes. I sand with finish and throw fine sanding dust to fill pits.
larry C
Elberta, Alabama
Larry
  • #13
That'll work fine, I do it also sometimes......it just depends on the effect I'm trying to achieve with the final finish...
Mike1950
But on boxes above I did none of that- sanded to 220 used gloss finish and very fine steel wool to make satin with a antique wax. I like the wax for the soft silky feel.
ironwood man
Cortez Colorado
When working with burl I agree it needs to be sanded quite fine. We made thousands of boxes sanding to 400 to 600 grit using kingsport paper for final finishing. It was yellow and was designed for stainless steel. After that we buffed with green Tripoli about 1600 grit and then oiled our boxes in a thin citrus based oil that did not have the petroleum smell of Watco. Final top coat was buffed on carnauba wax. Maintenance can be polish with a soft cloth or rebuffed.
Good luck
ironwood man
Cortez Colorado
The oil use to be made by Livos. I think it was boiled linseed. The unique part of their blend was the thinner made from extracts of citrus fruits that made it smell good and gave it a nice thin consistency for great penetration.
