I've tried to search for previous threads about the most accurate way to make miter cuts for boxes. But didn't find any so I probably wasn't doing something right. I'm sure this topic has been discussed before. I'm interested in finding out how you box makers cut 45 degree miters for box sides? A buddy has a jig he built that he swears is the best way to cut box sides on his table saw without tilting the blade. Much more accurate than using a chop / miter saw. I've seen some YouTube "how to's" for building a sled type jig for cutting 45 degree miters, but it only works for small dimension, not for cross cutting box sides for example. If someone knows this was talked about before and can post a link to the thread, that'd be great. Otherwise, I'm all ears, looking to be educated about making boxes with 45 degree miter corners and splines. Thanks
