Ask the guys on Primitive Archer. Yellow Birch can make make a very fine bow, but it isn't really a beginner wood if you are trying to get a 50lbs bow out of it. Natives used green spruce limbs until they dried out. If you have juniper, that would be the way to go with a birch baking strip or a rawhide one. If I was in your position, I wouldn't try a recurve until you get a longbow down. Longbows shoot more accurately as well. You should aim for a bow at least as tall as you for starters. Get a large diameter clean log of yellow birch (should be easy!), split it into staves, let them dry for a year minimum. The larger the log the better since a longbow design will benefit from less of a curve in the growth rings. Too round a curve will present problems. Go online and ask for a longbow design measurements from someone who has made a yellow birch bow on Primitive Archer. You need a wood specific design since all wood has different density. Birch is pretty dense, so my guess is an ash longbow design would work just fine. After you have your design, GO SLOW! Be sure to remove ZERO wood from the back of the bow (just remove the bark) as you will need one unviolated growth ring on that side to keep it from blowing up. After you are about midway through tillering (maybe at 20inches) get a heat gun or just a charcoal fire going and gently roast the belly of the bow (the side that will face you) for around an hour making sure it NEVER turns black. Just like roasting a marshmallow. Take your time and slide the limb back and forth above the coals, never allowing it to rest long in one spot or you'll burn the wood. Give it a few days afterwords to recover and then go back to tillering it out. You will have a good bow that handles compression better than before due to the roasting process. It will also take less set. If you are concerned about it more, get some rawhide and back the back with a strip of it. The process for this is super simple and can be found online. I personally feel the safest design for beginners and for woods that are not premium bow woods is to use a pyramid design. They are simple to make, they balance compressive and tensive forces in the wood and they shoot surprisingly well. The only thing I don't like about them is that they are quite bulky. I understand it would be more difficult perhaps to hunt with a longbow, but most shorter design bows require either uncomfortable or difficult firing techniques or a lot of knowhow into mixing natural materials that can take a really long time to get down. You just can't get the draw length you need to get a stable anchoring point on your face with a short bow. This makes shooting less accurate. If I found some juniper where you were, I would make a sinew-backed juniper bow that was reflexed with static tips like Ishi made. They hammer, they are light and they are super short. Chuck Leoffler (Heart Wood Bows) has a video online detailing an Ishi-styled bow start to finish in a six part video series. If you get ambitious, go for it. Let me know how it goes or if you need anything,
I know nothing about bow making but tamarack is very common here and I have used a lot of it for various projects. It might be worth experimenting with. It is pretty strong and will take quite a bend without breaking. I have split quite a bit for firewood and knot free sections split pretty clean. The Abenaki people called it hackmatack which means wood used for snowshoes.
You wouldn't normally want to use a conifer short of juniper or incense cedar (is yew conifer? I forget) for a lasting bow. They don't normally handle compression or tension well enough to make a high poundage bow. Compression conifer is totally different and can be used as the belly of a bow since the cellulose formed in a tilted conifer tree is much more similar to horn than wood. It needs a backing though and will act weird if there is a lot of moisture in the air. Other wood you might have around are cultivated fruit and nut trees. Apple, plum, pear and crab apple are fantastic. Black cherry can be used with caution and a rawhide backing. Black Walnut is good in northern ranges. Another option, just pick up a hickory board from your local wood shop. The stuff is quite nearly indestructible. Here is some additional infor about compression wood since it is likely a good option in your area: https://lintukoto.wordpress.com/2010/04/17/lyly-or-compression-wood/
Although tamaracks qualities are conifer like and probably not a great choice for a bow it is actually a deciduous.
Jack pine is also known as grey pine or pin gris.
http://www.blueplanetbiomes.org/jack_pine.htm
So I suppose that in this case there is two types of grey pine.
The California and Jack.
Yes, you are actually really lucky then because it isn't normal to find it. It is usually grown for the purpose of compression wood. Again, use the compression wood for the belly of the bow, not the backing strip. As in, the compression wood should be facing you when you draw the bow and the birch should simply be a thin layer (maybe 1/8th of an inch) of wood over the top of it to keep it from splintering. You could also use sinew or rawhide if that is easier. FYI, sinew is not easier although rawhide would be. You can make a shorter bow (lets say for starters 62-64'') since this wood combination will hold up quite well. Read that article closely and be careful to ID it correctly or you'll have a giant failure waiting to happen. The stuff is super dense as compared to the wood itself. Usually around .70.Wow I just read the link you gave me and I suppose I'm a lucky guy because I have tons of these leaning trees due to wind. I didn't know about compression wood before this. Really awesome stuff.
So I suppose I will go with a yellow birch and compression wood backing bow. Sounds like the best option for me.
I might sound a little hard headed because I agree that it would be much easier for me to get better hardwoods.
The problem is that it wouldn't be a bow I can make from local trees and that's important to me. I want to be able to show others how it's possible to source a decent hunting bow from local resources.
I think I might have a winning combination here.
I will pick out the bests staves I can find and post pics.
Have a great day!
One only needs to mill some crooked logs to learn about compression. The saying crooked logs make crooked lumber holds true. I milled a couple crooked fir last week and the lumber is all but unusable. Trees that are partially uprooted when they are small and then over the years try to grow upright are the worst, or in your case the best. Sometimes trees on the edge of a clearing will grow almost horizontal to reach sunlight then grow more upright as they escape the shade, you see this a lot on the edge of lakes and streams.
Yes, limbs are an easy way to get compression wood, but you will need to use two limbs and splice them at the handle as the majority of the compression wood in a limb is near where it connects to the tree and then it quickly thins out. If you are comfortable splicing, that isn't a problem. A simple 4'' V splice is sufficient for most bows if it is a clean cut on the bandsaw with no gaps. If there are minor gaps, heat the cuts over boiling water (not it) for around 20 minutes, then bind them together without glue tightly with some c clamps. Use some wood thins on the C clamp or else you will damage the splice area. Give it 3 or so days to dry and then glue it with a strong epoxy or hideglue. Make sure to clamp it after you ad the glue, but not too tightly or else you will drive all the glue our of the splice. Steaming a splice will make it tight as can be even if you messed up your cut.You are right. It isn't so easy to find. I went to the spruce stand I had seen with leaning trees but I realised they had grown straight and been knocked over by either wind or snow later on.
I didn't find the characteristic red color and the rings weren't on an angle.
I know I've seen others overhanging a stream. I'll check for them tommorow.
Man I thought I had hit the jackpot but it was too good to be true. Quick question. Do you think I could use a big enough limb if I can't come about a trunk? I figured that since they grow horizontally it must be compression wood also nah?
I'll keep you updated as I'll be actively on the lookout in the next days.
Enjoy your evening.
