Box Joints?
Discussion in 'Box Makers' started by Bigg081, Jan 23, 2019.
  1. Bigg081
    Bigg081 Connoisseur of Man Glitter Full Member Thread Starter
    961
    199
    Pensacola - Florida
    Shane
    Box joint jig gets here tomorrow but I haven’t been in the shop in a week. Damn thumb is keeping me down. I’m about to go nuts!
    I made an attempt at miter joints with a scrap piece. I used @Mike1950 ’s method with the miter saw. It’s not perfect but was some good clamp pressure and a tiny bit of sanding I don’t think anyone would ever notice. 2EA6E356-07CD-4BC5-9D5D-A2697FF7A37B.jpeg
    • Like Like x 4
  2. Mike1950
    21,750
    6,384
    Not bad and tolerance for error on something that small with that thick of wood is almost zero. Making boxes is about eye appeal. someone- I thing @Sprung mentioned thickness of wood needs to be proportional to box. Watch out though- falling into box vortex is almost as bad as lathe vortex-just one hell of a lot less chips. Lots of stuff in classroom on boxes.
    • Funny Funny x 1
  3. Ray D
    Ray D Member Full Member
    1,077
    351
    Lutz, Florida
    Ray
    Looks good. Check out the Merle band clamps. I like them a lot for boxes and picture frames.
  4. Gdurfey
    Gdurfey Member Full Member
    661
    396
    Falcon, CO
    Garry
    tried to do a picture frame from barn wood for a Christmas present...........like all the previous comments, I will be looking for better ways to remove the slop. ugh........thought I was so close until assembly time.
  5. FranklinWorkshops
    FranklinWorkshops Member Full Member
    2,122
    1,072
    Landenberg, PA, USA
    Larry
    Garry, barnwood is supposed to have cracks. You're too tough on yourself. It's character that people pay extra to get.
    • Agree Agree x 2
    • Funny Funny x 1
  6. Bigg081
    961
    199
    Pensacola - Florida
    Shane
    Thanks @Mike1950 I figure 1/2" thickness works for a big range of different size boxes.
    I have some really nice flat pieces that I got from Scott Satterfield (not sure his screen name) years ago. Some Goncalo Alves with a really pretty continuous grain that I hope to make a nice box with. Fingers crossed I will wrap the grain around the box correctly. I need to get some more Goncalo Alves to use for the top and bottom. Not really sure about any other woods that would look really well....maybe Wenge.
    I haven't looked into the classroom area yet. Thanks for the heads-up.
    I have a Bessey Strap clamp. I think it will work too.
  7. Schroedc
    10,316
    6,302
    Rushford MN
    Colin
    I like to do Mitre joints on my table saw. Invest in a Wixley digital angle gauge. between that and using a framing square to set up my crosscut sled I get perfect fit almost every time.
  8. Alex Beck
    Alex Beck Member Full Member
    54
    30
    Florida
    Alex
    Miters look nice but are weak due to the end grain glue surface, they need to be reinforced w/ splines which looks nice as well. Miters are also a pain to glue up. The best/most accurate way to cut a miter is on dedicated sled on your tablesaw. If you have a good quality chop saw thats properly aligned, that can work as well but always cut the material standing up on the edge grain. The blade seems to wander more if you try to cut it laying on the face grain. A shooting board is the best way to trim & adjust the miter joint. I'll also make the argument that box joints and dovetails are very close it in strength, box joints have more glue surface area and a dovetail has a bit more resistance to tension. A dovetail is harder to cut without gaps whereas a box joint is fairly easy to cut with the right jig. A dado blade will make it quicker as well.
Current Time: 3:45 PM
