Cool! What size are they? A buddy of mine has a cnc and is considering boxes. I have this nasty habit of stacking wood back and might talk him into a trade... I have a brother who LOVES dragons. I will have to start wrangling playtime. (If I ever get done with my animal houses.) (And sawmilling.) (And you know, the rest of it)
Nice boxes! I made a few a couple weeks ago but I need to do a little touching up on mine also. What size bit did you use to cut the inside?Had some slabs laying around, and a the CNC sitting idle so worked up a design for a completely CNC cut box. Still a little fine tuning on the square ones to make them fit perfectly right off the machine but they come out pretty decent!
Outstanding transfer of images! If you get a chance, please put together a tutorial on this. Thanks! Chuck
I bought a couple 4 inch squares of canary wood from John with the intention of making them into fly boxes. I'll have to make a new template for the router so maybe when I do that I'll take some pics. It's a pretty simple process. The hardest part is securing the template to the wood so it doesn't slip around while you're routing. It's actually easier to start with a bigger board so you have plenty to clamp on to and still have room for the router bed. But you can sandwich the fly box board between two other boards of equal thickness, use double stick tape, and usually get it secured. Once you have that, it's just driving the router around, increasing the depth, driving the router, etc until you reach the depth you want. Then trim any excess off the sides of the box, sand it, and make the mortises for the hinges.
Ah, well, I don't do that part. The guy who does lazer engraving does it. But from his description, you can use any photo or drawing you want. Select the size of resin coated disc you want and size your photo to fit. Then he prints that image on special paper that comes with the resin coated discs. Then he tapes the resin coated disc onto the paper, resin side in contact with the printed photo. He can do multiple discs as long as they fit on the page. Then he places them into a heated press for about 30 seconds. The image is transfered into the resin. He pulls them out, lays lays them on a flat cool surface, and then peels off the paper. That's all I know about it. Except the image disc are permanent and very durable. The resin can be scratched but otherwise it's pretty solid.pretty sure he's talking about the picture transfer part
Outstanding! What are the dimensions? ChuckFinally finished these. 5 coats of tung oil then buff polished. Glued in the toucan inlay with Gorilla glue. The ripple foam isn't glued in, in case the recipients want to use the box for something other than flies. I think these turned out really well and will probably make a few more.
Thanks, I do a lot for the vintage sewing machine folks so I've digitized a lot of vintage artwork. I start with a scan of a 100 year old piece of art and then a lot of photoshop work.That Singer engraving is way cool! Great idea to utilize all the small scraps around the shop.
