Chip out
tomwilson74
West Virginia
Tom
Is this due to dull planer blades? I’ve tried sending it thru in both directions. Can’t seem to plane it away
rob3232
WI.
Rob
Looks like snipe? If you run three pieces butted in a row through your planer the middle piece should be fine. The first and third usually will have this on one end. You can also build a sled to help with shorter pieces. If it is snipe try googling it.
Rob
tomwilson74
West Virginia
Tom
It’s happening all along the board, not just on the ends. I can get most of it out by starting with 40 grit sandpaper...
rob3232
WI.
Rob
Hmm . Have to see what others say. Nice walnut by the way!!
Patrude
Taunton, Ma
Rich
I have a typical problem with my DeWalt 13 & 1/2" planer. After research I learned it is the drive is skipping. I can get replacement bushings. Gonna give that a try
4jo3
Pittsburgh
Justin
Try spritzing the wood with water sometimes on highly figured wood I used to get tear out (I switched to a helical head since then) but that would be the quick fix.
