Clear filler for burly dining bench
Discussion in 'The Charles Neil Finishing Forum' started by Patrude, Sep 25, 2015.
  1. Patrude
    Patrude Member Full Member Thread Starter
    1,647
    380
    Taunton, Ma
    Rich
    I'm building a rustic dining table bench. 6' by 18". It's oak 5/4 oak burll with a lot of holes and bark inclusions. I think I would like to fill the voids with something clear so we can see what's going on in the wood. I'm not sure what to use. I thought about epoxy bar top finish but I'm uncertain if that would interfere with applying a satin finish to the bench top. Looking for ideas and suggestions, thanks
  2. Kevin
    Kevin Wood is good. Staff Member Administrator Global Moderator Founding Member Full Member
    30,921
    8,325
    Texas
    Kevin
    No the epoxy will not interfere - epoxy takes a semi gloss or satin/eggshell finish just fine. Scuff it up with 400 and you're good to go. I always fill the voids level with the surface before the flood coat because it works out better than trying to fill the settled voids after the fact.
    I'd love to see that board though!
    • Agree Agree x 2
  3. Patrude
    1,647
    380
    Taunton, Ma
    Rich
    I am at my part-time job right now, I will follow up with a picture come morning. The 18" width is from joining couple boards together. I've got 3 or 4 with the widest being 13 & 1/2". I haven't planed or jointed anything yet.
  4. Patrude
    1,647
    380
    Taunton, Ma
    Rich
    Sorry for the late pic, these are the boys I'm talking about , they're Spalted nicely too. Spalting but sound
    • Way Cool Way Cool x 1
  5. barry richardson
    8,253
    2,922
    This is a technique that worked well for me, flood the top with the epoxy and let it fill all voids, and let it cure, then sand or scrape it back down to bare wood. This will give you a flat surface with all the holes filled, then top it off with the poly of your choice, I had no issues with compatibility between the epoxy and poly. I like this method cause holes and cracks are filled but you avoid the plastic look of bar-top....
    • Informative Informative x 1
Current Time: 8:07 AM
