Custom diy collet jaws
TimR
Sawdust Engineer
Blairsville, GA
I needed a size of one of these to hold a piece of banksia pod for a peppermill I’m working on. They work great and add a little extra meat over typical jam chucks. Also, they allow holding the piece without marring the surface from chuck jaws.
I start with a piece of poplar scrap, about a half inch thick and about a half inch bigger or so in outside diameter to what I want to hold.
In this example, 1-1/2” is what I want to hold.
I drill that first hole about 1/4” deep but that can vary with size of your tenon you want to grip.
I follow with a 1-1/4” hole thru.
Note that I have marked where this piece of wood aligns in my chuck. I do this anytime I’m going to rechuck something to maintain good centering.
Mark a location to cut the piece between jaws, this gives room to clamp.
Cut a slit and put back on chuck.
F5361855-C3EE-49B0-A264-C4E1BA5DA4B8.jpeg 0F2C8E1A-4DCB-4DB7-A22C-379ADAD4E4F5.jpeg
Note that if you need more grip you could open the slit a little but the more you open it up or have to stretch the collet to get over the tenon increases the likelihood of losing good centering.
Graybeard
Wisconsin
Thanks so much, certainly much cheaper than buying soft jaws from Nova or whoever. I like too you can make them in different sizes for different projects. I'm definitely bookmarking this. Thanks for taking the time to put it together.
Nubsnstubs
Where is it???
Tucson, Arizona
Jerry
I've made one of these once. I used it, put it in a place I would instantly remember, and then, the black hole near my lathe appeared. You all know what that means
Since I have a bunch of chucks with jaws that the sizes all match up to the next size, I usually just went with the next size chuck. Today, reading this thread again, I was slapped across the side of my head with an epiphany. I'm drilling out those Cholla Tea Lights with a Forstner bit. Now, I'll make myself another one of these soft jaws, and when I punch through, I'll be into wood rather a set of jaws. Thanks for posting this. .......... Jerry (in Tucson)
DKMD
Sawbones
Nifty idea! Thanks for sharing it.
Mike Mills
NC
Looks good. Here is a pic which Stuart Ablett posted about 10 years ago. He used thick (1/2") cutting board from the dollar store but a 12"X24" sheet of HDPE is only about $18 on Amazon. I believe Stuart said he roughed it up with 80 grit to give it more bite and he did cut a slot in it for compression.
Wood works just as good but the HDPE may be more durable.
