Not sure if this is the right sub-forum, but looking for any experiential knowledge on some specifics in the subject of inducing spalting.
I’ve been reading and searching a bit, watching some videos on YouTube as well. Most of the info shared that I’ve found so far seems to be that the generally accepted methods are:
1) leave wood on the ground, possibly turning over time and waiting “a while.” This seems to be a little to vague for me to try and follow, as well as the longest time to results.
2) put wood inside of a plastic bag with shavings or dust from working other spalted wood and waiting “a while.”
3) put wood inside a plastic bucket with fungi cultures or other “stuff” from the ground layers that are decomposing and wait “a while.”
My search is for some clarity around the following:
- In the plastic wrap/plastic bag methods, seems like folks are just putting either fresh cut or dampened wood in a bag or tight plastic wrap.
- sometimes this is with sawdust or shavings, sometimes specifically from other spalted wood. Does it matter which? Do you need to use shavings or sawdust?
- how long does this generally seem to take? Some folks are saying 3-4 weeks, some 4-6 months…
- what kind of temps to keep this bagged or wrapped wood?
Has anyone tried to grow or encourage specific type(s) of fungi for specific results (color, thickness of zone lines, etc)
There seems to also be conflicting info about whether or not one can expect to see results when using wood that has already dried. Any experience with this variable?
I’m probably going to toss a couple pieces of wood in some plastic bags in the corner of the shed, some with shavings and some without (I don’t currently have any spalted wood shavings) and just give this a shot, but wanted to see if there’s any experience that can save me some failures along the way…
