**ENDED** dozens of curly walnut turning blanks sizes from 4-17" square and 2-5" thick!
Treecycle Hardwoods
West Bend WI 53090
As the title says I have dozens of curly walnut blanks for sale. The big one in the pic is the only one I have that big. It measures in at 17 x 17 x 5. The bulk majority of the blanks fall into the 6-8" square range and 2-4" thick. The medium ones in the pic happen to each be 7" square. One is 2 thick and the other is 3 thick. The little one is 4 x 4 x 2. I have almost 4 dozen pen blanks and another 3 dozen call blanks 1 5/8 x 1 5/8 x 6. I cut a few hollow form blanks and a couple pepper mill blanks as well.
If any of these sizes suit your needs drop me a line and I can put a package together for ya.
LemonadeJay
PA
Jay
Greg,
Is the 17" block still available? If so, how much are you asking for it?
Thanks,
Jay
Treecycle Hardwoods
West Bend WI 53090
Yip the big one is still up for grabs. I am looking for 60 plus shipping out of it. It is just shy of 10 BF.
LemonadeJay
PA
Jay
Greg,
I am going to pass on the piece this time because i realized i would need to buy an outboard tool rest too.
Treecycle Hardwoods
West Bend WI 53090
  • #12
Do you have any that are 8" square or larger that is 4" thick or 4" square and 10-12" long?
I will check on both of those sizes. I know I have some in the 8" range but the 4" thick and 8" square may be unlikely. If I have the hollow form size it will only be 1 or 2 of them. I know there are several hollow form blanks in there but I think they were cut at 9" long. I will keep my fingers crossed for you.
Treecycle Hardwoods
West Bend WI 53090
  • #14
OKie dokie here are the pix of the blanks I have that meet your specs. The biggest is 10.5 x 6 they all have measurements written on them. If you wanted more pix of a particular blank let me know.
After taking the pix I found 3 more blanks 8-10 square. There were 2 or 3 that were marginal.
All together I have 8 bowl blanks (5 pictured) and 2 hollow form blanks that fit your specs.
Treecycle Hardwoods
West Bend WI 53090
  • #15
How much would shipping of that 17" x 17" x 5" be to zip code 22302?
Total cost for the blank and shipping would be 103. That is using ups ground. I will check Fedex to see if there is a savings on shipping.
m34
Alexandria, VA
Damion
I want that blank, but I think it is just a little too rich for my blood right now. Thanks for going through and checking for me though.
Treecycle Hardwoods
West Bend WI 53090
  • #18
no worries I knew shipping would be a bear on it. It weighs 45lbs! I have others if you wanted a smaller one?
