- #21
I am sure the value would increase. If we can consider carving similar to veneer cutting there is data, and the there is data for finished veneer. Stage 1, i.e. rough cut boards, depends on the quality of the cut. A very rough cut would not show any chatoyance at all...was trying to give you a reference to measure it in different stages from 1 to stage 3. From flat book-matched, to carved staged to a clear coat finish stage. I wanted to see how much the chatoyance value changes (or it doesn’t).
This is interesting. Do you know if there's any data available about this? Also, considering that you mention different tap tones, what is violin back standard? Flat or quarterd?As far dimensional stability, it is much preferred due to stiffness and rigidity and for tensile strength. Take a 36” x 4” x 1” thick of maple that is a quarter sawn and a second piece that is flat sawn cut. Have cylinder blocks present from point A to point B. Set each piece about 4” or so overlapping the cylinder blocks. You can step on the middle at your own risk or put iron weights. You will see how one grain orientation would have a lot more flex than the other.
Anyway, also from what Frank was saying, it appears "common knowledge" that a carved (or planed os scraped) surface would be more chatoyant than the same surface when sanded. I wish I had more skill with such tools, then I could try.
Do they have the same surface quality? I would guess the flat face is planed while the side is cut in a different way...?the quarter sawn side edge has higher chatoyance to my eye
Also, do you know if the fibers are ondulated on the flat surface or on the quartered surface? That is, what happened in this log: A or B?
source: [Beals and Davis 1977]
Whether waves run side to side or in and out of the surface changes the relative position of the brightness peaks, so altering the way curl is perceived.
What I mean is visible in these two gifs below. Bear in mind that the light rotates around a vertical axis (perpendicular to the surface), performing a 360° rotation. Whatever happens in gif 1, it appears to be happening twice in the cycle. Differently, in gif 2 there is an evident asimmetry in the chatoyance cycle (curl is way more evident when the light goes from 9:00 to 3:00 than from 3:00 to 9:00).
So many variables
Thanks everyone for providing so much insight on this topic!!
