First go at wood laminating
Discussion in 'Veneering' started by cabomhn, Mar 16, 2012.
  1. cabomhn
    cabomhn Member Full Member Thread Starter
    1,251
    457
    Charlotte, NC
    So I posted in another thread about gathering some supplies for making an inlay for an upcoming project. I got some time today and did my first go at laminating veneer and thins together. I don't have a vacuum bag, so I used clamps, lots and lots and lots of clamps. :cool:
    http://www.woodworkingtalk.com/f9/how-make-inlay-25816/
    I am using that thread as my reference for this inlay. Here's a couple pics...
    [attachment=3104]
    [attachment=3105]
    I haven't gotten around to cutting the triangles yet, I'm making a table saw jig that will be able to be used for this as well as segmented cutting. Just need to get a couple toggle clamps and it'll be complete. Thanks for looking!
    - Matt
  2. chippin-in
    chippin-in Founding Member Founding Member Full Member
    843
    308
    Houston, Texas
    Robert
    Looks good so far. Maple and walnut?
    Robert
  3. cabomhn
    1,251
    457
    Charlotte, NC
    You bet!
  4. Mike1950
    22,708
    6,889
    Looking really good. Pictures of jig please- I have been thinking of this also- I have been thinking of setting up vacum to suck peices away from blade-is this a dumb idea??? anybody try that??
  5. cabomhn
    1,251
    457
    Charlotte, NC
    I'll be sure to post up a couple pictures of the jig here once I'm all done with it! I was thinking about using a toggle clamp to hold down the piece to be cut, but using a vacuum sure sounds interesting if you have the means.
    The jig should be able to handle cuts from 0 to 30 degrees on the TS.
  6. Mike1950
    22,708
    6,889
    Matt, I was thinking to set vac hose up on jig so piece cut got sucked into vacum when cut so blade did not touch again after cut then I would just retrieve from vac can. Maybe that will not be a problem But??
  7. cabomhn
    1,251
    457
    Charlotte, NC
    I actually thought that was a really good idea to try, I just don't have a vacuum!
  8. Mike1950
    22,708
    6,889
    Roy thanks, Jet and no vibration either-maybe overthinking process. I know I can't get to it for a while so all I can do is think about methods. Have plenty of projects to finish.
  9. Mike1950
    22,708
    6,889
    Matt, you are doing very good for not many tools........................
  10. Mike1950
    22,708
    6,889
    Roy that is almost evil to make something like that-makes me dizzy just looking at it.:wacko1::wacko1::wacko1::wacko1: and it was pushing the envelope to claim that I was anywhere near normal before that.........
  11. cabomhn
    1,251
    457
    Charlotte, NC
    It's even better looking in person!
Current Time: 12:34 AM
