First two dough bo
Discussion in 'Carving Forum: Hand, Power, & Chainsaw Carving' started by David Van Asperen, Dec 12, 2017.
  1. David Van Asperen
    David Van Asperen Member Full Member Thread Starter
    2,390
    620
    Carthage, South Dakota
    Here are the first two attempts at power carving dough bowls. The second one I attempted a rim. These were carrying moisture so the are coated with mineral oil hoping that will slow or stop the cracking. I need to get some sanding equipment that can do the curves and reach into the bottom
    I am really fortunate that my bride wants machining mark left on them so no futher sanding on these YET
    • Way Cool Way Cool x 3
  2. kweinert
    kweinert Member Full Member
    2,325
    1,356
    Thornton, CO
    Ken
    Nice work.
    The first (and only) dough bowl I made was segmented. And I didn't have the right tools to smooth it out correctly. I ended up making a sanding mandrel out of some flip-flop material and used 2 or 3" sanding discs on a coarse grit to sand it down.
    You'll probably get a request to sand it more the first time dough sticks in it and it takes a long time to clean :)
    • Informative Informative x 1
  3. David Van Asperen
    2,390
    620
    My wife wants to use them as table center piece things ,you know pit different do dads and whatnots ,some garland abit of ribbon or a bow. I agree that fu her sanding will be beneficial and if I make some more for its more intended purpose I most likely will need better sanding equipment. But for now I am blessed with them being " just the way I want them"
  4. Tony
    13,623
    3,804
    Tony
    Nice bowl David! Tony
  5. David Van Asperen
    2,390
    620
    Almost afraid to say it ,but I think I like making them. Got a grinder with the right type of switch, but it still has me thinking on each cut ,not just where to cut but how to so I don't create a kick back situation,
    . These will run away with you if you are not paying attention.
  6. barry richardson
    7,692
    2,710
    They look great! What kind of wood? I just use an ROS to sand the inside of big bowls like that
  7. David Van Asperen
    2,390
    620
    @barry richardson
    This is maple, was going to be firewood until my bride decided that she wanted a dough bowl.
    The bottom I can sort of get with the random orbit sander. The ends are a little too narrow as I sloped it in towards the bottom both on the ends and sides.
    Thanks for the input it is always useful and appreciated for me.
Current Time: 10:27 PM
