Glue for veeners
Discussion in 'Veneering' started by Treecycle Hardwoods, Jan 27, 2015.
  1. Mike1950
    21,750
    6,384
    Not you or I -Greg clarified what he was doing halfway through.
  2. Treecycle Hardwoods
    Treecycle Hardwoods Founding Member Founding Member Full Member Thread Starter
    5,218
    1,103
    West Bend WI 53090
    sorry guys I should have said what I was doing from the start.
  3. Mike1950
    21,750
    6,384
    No matter- made for more info!!!
  4. Schroedc
    10,316
    6,302
    Rushford MN
    Colin
    I've been following this and am seriously considering buying a vacuum bag since I already have a couple vac pumps....
  5. Steve Smith
    Steve Smith Member Full Member
    1,170
    376
    Bothell, WA
    Steve
    the bags are expensive for the good ones, but they make successful veneering of large panels so much better.
    I'm curious for the weldwood, do you use a foam rubber roller as you do for other liquid glues? I've used weldwood, but not for veneering.
  6. cabomhn
    cabomhn Member Full Member
    1,251
    457
    Charlotte, NC
    You can make a vacuum bag for much much cheaper than you can buy them for and they perform excellently! I put up some of the steps similar to the joewoodworker site in my box thread on here.
  7. tocws2002
    tocws2002 Member Full Member
    1,207
    485
    Shelbyville, KY
    -jason
    This. You can definitely make them a lot cheaper than buying. I made a 4' x 4' and have enough material left over for an 8' x 8' bag and I have about $30 in vinyl and glue. Made a closure with two different diameters of PVC pipe.
    -jason
  8. barry richardson
    7,997
    2,835
    Weldwood sells both contact cement and the plastic resin glue. But now that I think about it, I spread them both the same way, along with about any other glue or epoxy, I use an old credit card, motel room key card etc, and squeegee it around, got the tip from some magazine, works great.
    • Informative Informative x 1
  9. Treecycle Hardwoods
    5,218
    1,103
    West Bend WI 53090
    Ok here is the glue I bought to try on my project. My local ACE also had the weld wood product but this was a bit cheaper and seemed like the better choice. Hopefully it was the right call.... if not I can always go back.
  10. chicago
    chicago Member Full Member
    189
    68
    Land of Enchantment
    Phillip
    I use hot hide glue for all of my veneer work. I kept away from it for years, but now would use nothing less. It definitely takes some setup time, but I love the fact that if you are not satisfied with your results all it takes is a bit of heat and the veneer can be re-worked. That is the reason that violin/guitar maker's use hide glue.
    Here is some info you may find helpful.
    http://www.wwbydesign.com/veneer_adhesives.html
    http://www.xrestore.com/Pages/HideGlue.htm
    http://woodtreks.com/animal-protein-hide-glues-how-to-make-select-history/1549/
    The following hot hide glue brand - Brooklyn Tool - was my go-to source for HHG, but I see that Woodcraft has now got their finger's in the pie.
    http://www.woodcraft.com/Product/15...d-Craft-Hide-Glue-251-Gram-Strength-1-lb.aspx
    Best of luck on your project.
  11. barry richardson
    7,997
    2,835
    I see you got it on sale so it could be old stock, I don't have any personal experience but I have read where the pre-mixed hide glue like that has a rather short shelf life, it should have a use-by date on it...
  12. Treecycle Hardwoods
    5,218
    1,103
    West Bend WI 53090
    I should look at it once and see. I have used it on 2 boxes so far with good results. I should be in the shop now working but I'm being lazy today. Maybe after dinner.....
Current Time: 3:41 PM
