Math Question
Johnturner
Proud Member
Burlington, MA
Is there a way to determine what the maximum diameter that can be turned from a square piece of wood?
For example You have a blank 2"x2" x10" Can you get a 2" diameter blank? Thanks John
Albert Kiebert
Tidewater Virginia
Albert
Max. Dia. of a square piece of wood ??? The way I find out is to first, find the center of smaller end then take a compass and set it in the center with one leg and touch one side with other leg, then sweep compass in circle, adjust center until you get a full circle around your square piece of wood. That will tell you your max size, then do as Jerry mentions above.
You just have to be extremely precise in centering it
TimR
Sawdust Engineer
Blairsville, GA
John, the short answer is a square blank, centered precisely, will yield a diameter that is the same as the width of the sides. That being said, almost always off by about 1/16”, so always start with a blank with sides just a little more than final diameter wanted.
Johnturner
Proud Member
Burlington, MA
Thanks Tim that is the answer I was looking for
Patrude
Taunton, Ma
Rich
I find center , use an awl to mark it and scribe a circle. That's only going to get you a close idea of what you can get out of the blank. Once its mounted you may end up taking more with your roughing out.
