You're living the dream right there!
Your pictures are just fine. I posted a picture of what a clean shop could look like and the picture sent Kenbo into a catatonic shock.:davidguil:Steelart99 said:davidgiul said:A beautiful shop and setting. But it is too clean. You are going to give Mike1950 a complex and make Kenbo jealous.:davidguil:
CLEAN ...:wacko1:
I must take lousy pictures
davidgiul said:Your pictures are just fine. I posted a picture of what a clean shop could look like and the picture sent Kenbo into a catatonic shock.:davidguil:Steelart99 said:davidgiul said:A beautiful shop and setting. But it is too clean. You are going to give Mike1950 a complex and make Kenbo jealous.:davidguil:
CLEAN ...:wacko1:
I can think of way worse addictions than the ones you just listed. Wood and tools seem to be my weakness for the moment.Steelart99 said:davidgiul said:Your pictures are just fine. I posted a picture of what a clean shop could look like and the picture sent Kenbo into a catatonic shock.:davidguil:Steelart99 said:davidgiul said:A beautiful shop and setting. But it is too clean. You are going to give Mike1950 a complex and make Kenbo jealous.:davidguil:
CLEAN ...:wacko1:
It turns out that not only am I now addicted to, and collecting wood, I've done the same with tools, fossils, meteorites, metals, stones ... sigh ... fortunately my wife is a saint ... and I make her lots of cool stuff so she wont dump me.
:rofl2: What??? I'm not the ONLY one???davidgiul said:I can think of way worse addictions than the ones you just listed. Wood and tools seem to be my weakness for the moment.Steelart99 said:davidgiul said:Your pictures are just fine. I posted a picture of what a clean shop could look like and the picture sent Kenbo into a catatonic shock.:davidguil:Steelart99 said:davidgiul said:A beautiful shop and setting. But it is too clean. You are going to give Mike1950 a complex and make Kenbo jealous.:davidguil:
CLEAN ...:wacko1:
davduckman2010 said:thats beutiful dan i got to build me somthing just like that right in the middle of my honey hole next door. where did you get the planes for that building. or is it a kit ? thats perfect for what i need . iv been clearing a spot in there but i got these dam big maples in the way but i got a an idea for them :csnut: they will look better in the house than out side of it yep duck
Steelart99 said:davduckman2010 said:thats beutiful dan i got to build me somthing just like that right in the middle of my honey hole next door. where did you get the planes for that building. or is it a kit ? thats perfect for what i need . iv been clearing a spot in there but i got these dam big maples in the way but i got a an idea for them :csnut: they will look better in the house than out side of it yep duck
Dave, no plans, I designed it myself and drew it up on AutoCad. I wanted to use what is called Socket Systems, the black steel angles at the beam interfaces. That way, I could build it on the ground and raise the beams as a single unit. No crane required. 8x8 Doug fir beams cut to length, bolted together and raised with a winch attached to my jeep. A bit hairy at times. I just used 2' dia x 4' deep concrete pillars under the beams. No other foundation required but I added a concrete pad too. The entire downstairs interior is blue pine T&G which was actually cheaper than anything else. I have 8 wooded acres and great views. You should build one yourself. I'll help ... from here.:i_dunno:
