Tony, gaskets should not be a problem. I was told that Grainger weren't going to sell the gaskets I need so I bought 4 back in 2003, and still have 2 at this point.
Something else to consider is, San Antonio is larger than Tucson. You should not have any problems finding an outlet that sells gaskets. If they do not stock your gasket, they certainly have gasket sheet goods that you can buy and make your own gasket. All you need is a lathe that's swing is larger than the OD of the tank you need a gasket for, some double sided tape, a piece of MDF large enough to tape the gasket material to, and the gasket material. A sharp skew is a must. With the gasket material mounted onto the MDF, MDF mounted onto the lathe, sharp skew in hand, turn on the lathe and cut OD with the point down in a vertical position. When that is cut, go to the inside mark, and cut it. It could be a 1/4" wide ring, or a 1/2" ring. The only thing that matters here is that you have that ring well secured to the tape.
I've made a couple pressure tanks for myself, and since there were no readily available gaskets, I had to make my own. It's a piece of cake. Even you could do it.
If you think you want to see a picture or 2, I can do that........Jerry (in Tucson)
