For you box makers, what thickness of wood do you like to use for boxes? Any rule of thumb depending on how large the box is? Thanks! Chuck
And don't forget what hinges you plan to use. That's always a big factor in my box design. Because I like thin sides, even the smallest 2 screw hinges at the big box stores are too wide. That's why I really like that inlaid brass pin hinge that Ray ( @Ray D ) showed us how to make. It works on any thickness.There is no rule to this- it is based on personal preferences, proportional and balance implementations. Ideal range from 1/2” to 1/8”. The thinner dimensions are based on liner additions or divisions inside the box- such as cigar humidors or divisions for jewelry compartments.
You also have to figure in any fabric liners and any padding for the bottoms or even the sidewalls (jewelry boxes).
Link?And don't forget what hinges you plan to use. That's always a big factor in my box design. Because I like thin sides, even the smallest 2 screw hinges at the big box stores are too wide. That's why I really like that inlaid brass pin hinge that Ray ( @Ray D ) showed us how to make. It works on any thickness.
Here’s a short video showing how to retract the pin. Seems easy enough to duplicate with a brass rod (cutting grooves on lathe) and using some springs from old click pens.I can't find the thread I'm thinking if in which Ray described how he makes these hidden hinges with 1/8" brass pins. Those ones you pictured are the spring loaded pins, right? You drill a hole longer than the pin, insert the spring, then the pin, then put the box together. The spring allows you to retract the pin if you need to remove the lid later after the box is finished. I haven't used those.
Will be on the small size, at least to start, probably 6"x10" or somewhere in that range. ChuckMost of mine are 3/8. And agree with Mike - what are you making?
I will have to review this. Hadn't thought about hinges or clasps yet... Was so focused on the wood at this point. ChuckAnd don't forget what hinges you plan to use. That's always a big factor in my box design. Because I like thin sides, even the smallest 2 screw hinges at the big box stores are too wide. That's why I really like that inlaid brass pin hinge that Ray ( @Ray D ) showed us how to make. It works on any thickness.
