question on removing lacquer
Discussion in 'The Charles Neil Finishing Forum' started by bobhasen, Jan 3, 2016.
  1. bobhasen
    bobhasen Member Full Member Thread Starter
    72
    32
    Ohio
    Bob
    I finished one of my first bowls in lacquer but the quality of the bowl was not that great and the finish job poor also. What is the best way to remove cured lacquer.
    Thanks,
  2. Woodman
    Woodman Kindling Maker Full Member
    317
    292
    New Jerzee
    Kevin
  3. Schroedc
    10,448
    6,457
    Rushford MN
    Colin
    I use Lacquer thinner to remove Lacquer, stinks and you want to be well ventilated. You will probably get some soaking into the pores of the wood so when you sand it back out don't get too aggressive so it doesn't heat up and smear. Makes a pretty good sanding sealer in a case like this. You'll probably need to stick with a Urethane or Lacquer finish when you redo it as I've run into issues in the past with things like Danish oil not wanting to penetrate in any areas that might have had some Lacquer soak in...
  4. bobhasen
    72
    32
    Ohio
    Bob
    Thank you
  5. Charles Neil
    Charles Neil Member Full Member
    123
    92
    New Market Va
    Charles
    I agree, a chemical stripper is the best, it seems to do a more through job, and Lacquer dissolves pretty easily , or if it can go back on the lathe , just sand it off .
  6. bobhasen
    72
    32
    Ohio
    Bob
    Thanks, unfortunately putting back on the lathe won't work, not enough material for the amount of distortion from drying
Current Time: 12:45 AM
