@rocky1 - he knows bees not eggs.
I am moving to Leesburg VA, are you sure that is your final answer?
He emailed it to me but thank you good sir.
I sent this one to Don also since it requires a lot less thinking.He emailed it to me but thank you good sir.
I found a calculator online but wanted to see if you guys had any thoughts on how to create a plan to build a segmented blank.
There are some that have space between the segments and others are butted up against the segments. The math for a blank that is butted together is easy to figure out, what I am wondering is if the math is different for the ones with spaces? A spread would change the circumference and while I have not yet tried this I would like some feedback on how to avoid potential pitfalls.
Also if there is any pointers on how to draw out a design. If you have something you have used as a successful drawing I would really like to see it, not to copy your design but to see how it was worked out on paper.
I never use any math for mine so I'm no help on that.
I'm not real sure Don's going to want a head spine. It sounds very painful.he will make your head spine............
Sounds right up @Don Ratcliff alleyI'm not real sure Don's going to want a head spine. It sounds very painful.
Must be in his bomb shelter. Probably no Wi-Fi down there.Where's @Don Ratcliff been? Haven't seen him on in a while.
