Hello folks..
At this time I woud like to share a side sharpening jig .
I always prefer side sharpening but normaly the jigs avaible are over stone jigs.
I had this idea below and using wood,aluminun and brass I did the jig.
I used an old slide cabinet door wheel.A 5 mm bolt limit the angle (up and down) at hinge.
It works nicely and it is very simple to do.
Woods are Gonçalo Alves and Pau Ferro (the thinest part).
Gonçalo Alves scientific name =Astronium fraxinifolium
Pau Ferro scientific name=Libidibia Férrea.
The wood and stainless steel hinge
The brass lock
The knob has patina
The wheel
One angle
The bolt limit the angle.The blade can go up and down changing the angle too (plus the bolt up and down)
Other angle.The blade locked by brass knob and aluminum bar
The back view.The bolt can go up and down changing the angle.
At center the aluminum bar lock the blade at slot
The brass lock
The knob has patina
The wheel
One angle
