(Solved) How to attach maple veneer for a roof shingles effect?
I'd worry about the steel rusting, unless you ordered stainless?
Two thoughts come to mind. First, exterior glue with a rub joint. Simply put glue on a piece and rub it in place for a few seconds until it becomes sticky and stays. Try it, you'll be amazed how well it works. If your shingles start to slip a little, angle the mailbox so roof is horizontal.
Second is exterior glue again, but use a drop of CA GLUE to hold the shingles in place while the glue dries.
polyted
Abingdon, Maryland
Paul
  • #22
Yep, rubbed joints are the best, especially with hide glue. The thing is, these shingles overlap each other so the contact surface is not that great. I have yet to experiment with CA glue :) The product I ordered says stainless steel.
polyted
Abingdon, Maryland
Paul
  • #23
Folks, so many good ideas around with two principal themes of using fasteners or adhesive. On reflection I came up with a compromise approach: I ordered $7 worth of 24 gauge steel wire. I will pre-drill all the panels (stacking them together to make it a breeze) in two places, then simply "sew" them on the mailbox like jewelry, haha. Thoughts? Either of the proposed approaches is high either in time (screws) or cost (adhesive). This I hope will meet the two in the middle, I hope to advantage. Thanks!
When its done I plan to coat the whole thing liberally in spar urethane and make the mail lady happy!
steve bellinger
bethel springs TN
Steve
I know I’m late for this party but,I’ve made a number of bird houses over the years with shingle roofs. I always used liquid nail with good results. Now I think if I make anymore I will use loctite sure grip. Just put a dab on and it sticks and stays in place. The thing with liquid nail is they would slide till they dried. Loctite don’t. I have used loctite to hold tile to walls with no problem doing repair work.
Wildthings
ASTROS 2019 WORLD CHAMPION VIDEO PLAYERS
Gulf Coast of Texas
I use Loctite Sure Grip to secure the tail feather quills to the form when mounting my birds. Good stuff
polyted
Abingdon, Maryland
Paul
  • #27
Interesting how much subtlety there is in glue types and applications. For this small project I bought 316L type steel wire and currently threading my second layer of shingles. Painstaking method but results are sort of what I was envisioning. Will post a pic when it's done!
Wildthings
Gulf Coast of Texas
Looking forward to the pics. Be sure to take progress pic just not finished pics. Oh and I don't think the wire would work for the tail feathers!
polyted
Abingdon, Maryland
Paul
  • #29
Work in progress ... It's more of a pain than I thought it would be. I'll attach final pictures soon. If I had kids I'd give them this project - feels like I m building a birdhouse.
