Spear point with Snakewood
TimR
Sawdust Engineer
Blairsville, GA
Just finished this for my nephew. The steel is from preground Woodcraft kit. This is my second knife, and the sheath again took way more time than the work to cut and attach scales. Note to self...leave more room next time for wet forming...barely got this one stretched enough, but has good resistance without being a chore to remove and restore. Knife blade a bit over 4”, 8-1/2”overall. Made mosaics myself too.
TimR
Sawdust Engineer
Blairsville, GA
Thanks guys. I like using snakewood if for nothing but waiting for impending doom of a crack. Right @Eric Rorabaugh and @ripjack13 ?
I’ve been lucky in none of my snakewood projects has resulted in any cracks. I know...shouldn’t have said that! :scare2:
Just because you said that, my snakewood heard it and cracked....
Gee thanks Tim...
:greeting:
Seriously though. That looks real good.
How do you make the mosaics? You should make a how to topic....
DKMD
Sawbones
Very cool! Love the pins too!
TimR
Sawdust Engineer
Blairsville, GA
  • #13
Thx Marc. I made the pins about 4 yrs ago, pretty sure I remember what I did. :old: The basic concept is to assemble the pieces, about 3-4” length max, epoxy up one end about 1/4”, let cure, then mix up some epoxy (Color as desired) in a Dixie cup, quickly place the rod open end into the wet epoxy and place under vacuum. Can’t mess around too long if using fast cure epoxy, the idea being to look for significant lessening of bubbles out of the epoxy, then slowly decrease vacuum to let epoxy get drawn up the tube. Get the tubes out of the vacuum chamber and place open side ofbtubes up while finish curing.
Strider
Croatia
Loris
Gorgeous! I hope you didn't have any mishaps when making the hand. I've had it explode in my face several times!
