Tandem axle short bed trailer
Discussion in 'Kenbo's Chat Room' started by woodtickgreg, Mar 11, 2018.
  1. woodtickgreg
    woodtickgreg scroll, flat, spin Staff Member Global Moderator Forum Moderator Founding Member Full Member Thread Starter
    13,629
    4,840
    I had a great deal on a tailer fall into my lap. I had to buy it, i couldnt pass it up because i have a need for it, i have a lot of work to do around my house and I would rather beat up a utility trailer than my new truck, lol. It's a 6 x 10 tandem axle, has new wheels and tires, the tires still had the stickers on them, the seller said it has new wheel bearings that I will still remove and inspect just to make sure everything is ok. I have plans for this trailer that include a new wood deck, side walls, and mounts for a magnetic trailer light assembly. A friend of mine did that and it is really cool, no lying in the ground to repair your trailer lights or wiring. I'll add tie down loops and a system for using my receiver hitch mounted winch, I'll be able to pull logs up onto the trailer when I need to. Hears a pic I took when I picked it up.
    I need to get a drop ball mount for the receiver to level out the trailer.
    The trailer towed well, tandem ride very smooth and don't bounce all over the place. A good solid chassis with a lot of potential to make it the way I want it.
    I can use the mig welders at work, and my boss will order me the tubing I need for the side walls with the company discount. I have a stack of elm that will make nice side boards. Elm is very flexy and not brittle.
    • Like Like x 5
    • Way Cool Way Cool x 4
    • Funny Funny x 1
  2. Tony
    14,495
    4,086
    Tony
    Great find Greg! Tony
  3. rocky1
    8,289
    3,237
    Way North Florida
    Rocky
    Dependent upon intended loads I don't think I'd drop it much Greg, tongue weight on the trailer will set the back of the pickup down too. You don't have a lot of trailer behind the wheels to balance load and level it, so it's probably going to pull a little heavy on the tongue. If you level it empty, you'll be low loaded.
  4. woodtickgreg
    13,629
    4,840
    It's only gotta come down an inch or 2, and I know about keeping the tongue heavy. but the way it sits right now because it is such a short bed the front wheels aren't even on the ground, lol.
    • Sincere Sincere x 1
  5. Nature Man
    Nature Man Member Full Member
    6,103
    773
    Redding, CA
    Congrats! Great snag! Chuck
  6. rocky1
    8,289
    3,237
    Way North Florida
    Rocky
    Yeah... our forklift trailer is the same way on the Duramax. Sits a little high on the tongue with a 1" drop, almost right with a 2" drop, but when you load the truck, it runs down hill 2 - 3 inches.
    • Informative Informative x 1
  7. Bigdrowdy1
    Bigdrowdy1 Member Full Member
    2,975
    1,210
    Big D Texas
    Rodney
    Looks like a road trip setup to me!:wink:
    Congrats Bud
    :cowboy:
    Rodney
    • Agree Agree x 2
  8. woodtickgreg
    13,629
    4,840
    Well it's been a little over a year since I got this trailer, it has served me well. But now it's time for some upgrades. Most of the pine decking wood is completely rotted, I could literally poke my finger through it in places. So off the deck goes. I still have to grind some off the old screws off. The trailer will also get some 2' sides welded up out of 2" square tubing. The deck will be 1 1/2" red oak, have not decided what the side wall wood will be yet, maybe elm if I have enough. I plan to weld tie down loops inside and outside of the trailer. A mount for my winch will also be done so I can drag logs up on it if need be. Some kind of removable gate or maybe 2 swing out gates that are removable. Here is what I started with today.
    20190527_115217.jpg 20190527_121438.jpg And it's off. Wood was very waterlogged and rotten.
    20190527_134242.jpg Its got one bent crossmember right between the axles that will be replaced.
    20190527_134309.jpg The debris is all cleaned up.
    Ripping the deck off allows me to give a good inspection to the main structure and springs etc. The fenders are pretty neat up but I dont think I'm going to change them, everytime you blow a tire it just beats the hell out of em anyway. So I'll just straighten them a little and call it good. Once all the excess brackets are cut off and the new sides welded on the whole thing will get painted with black rustoleum.
    • Way Cool Way Cool x 2
  9. woodman6415
    woodman6415 Member Full Member
    3,753
    1,617
    Pipe creek Texas
    wendell
    Great buy .. nice trailer
  10. woodtickgreg
    13,629
    4,840
    You saw it, was the same trailer I brought down to @Bigdrowdy1 Rodney's
  11. woodman6415
    3,753
    1,617
    Pipe creek Texas
    wendell
    Slept since then
    • Funny Funny x 4
  12. Tony
    14,495
    4,086
    Tony
    Plus, he's VERY old:sarcastic:
    • Funny Funny x 1
  13. rocky1
    8,289
    3,237
    Way North Florida
    Rocky
    Doesn't appear to tilt, think I'd go with a fold down gate, make it easier to slide logs in than swing out gates, even if you had to back down in the ditch, or dig the tires down. Fabricate your hinges out of pipe and cold rolled steel, you could pin each side and make it easily removable.
    Now would be a GOOD time to rewire it all too.
  14. woodtickgreg
    13,629
    4,840
    @rocky1 Nope, it's not a tilter. I kinda like the idea of 2 swing out removable gates. For loading logs I'll just use a channel to guide the log up. And I plan to make my own hinges out of pipe and solid bar so I can just lift the gates off if need be. I want this trailer to be very versatile in Its uses. Wiring is going to be stupid simple. A friend of mine has a trailer with a set up that I really like. He just welded 2 flat plates to the top rail at the rear, he then sticks magnetic lights to those. The cool thing about this is that the lights are nice and high for visibility, they are cheap and bright, and you never have to lay on the ground to fix your trailer lights.
    • Like Like x 2
  15. ripjack13
    ripjack13 ɹǝʇɹɐqpooʍ Staff Member Global Moderator Forum Moderator Full Member
    23,063
    5,795
    How did I miss this the first time.
    Belated congratulations on the trailer. And cool beans on the rebuild!
    • Funny Funny x 1
  16. CWS
    CWS Member Full Member
    3,063
    1,174
    Logan, Ohio
    Curt
    I know.:coffee1:
  17. woodtickgreg
    13,629
    4,840
    Worked on the trailer some today. The plan was to cut off anything that wasn't going to be used and grind everything flat.
    I had four of these stake pockets to cut off. Sawzall and a 14tpi blade did the trick.
    Next to go was the light brackets since I wont be using these. New ones will be mounted up high.
    There was an old trailer jack mount that took some time to grind off but it's off too.
    One of the fenders had broken free in places, both are really beat up. So I decided to cut these off too and I'll get new ones after the side walls are welded up.
    Both of the fenders are now off, only thing left to do is remove the wheels to grind the stitch welds flush so mounting the new fenders will be easier. But by the time I got to this point my back was very fatigued and I decided to save the grinding for another day.
    • Way Cool Way Cool x 1
  18. woodtickgreg
    13,629
    4,840
    All of the old screws have been ground flush from above as well. I have one cross member that is bent and needs to be cut out and replaced. It's a 2" x 3" angle iron, I dont have any of that so I'll need to pick a piece up.
  19. CWS
    3,063
    1,174
    Logan, Ohio
    Curt
    Looks like you are making good progress
  20. woodtickgreg
    13,629
    4,840
    Slow and steady, like the tortoise
    • Like Like x 2
Current Time: 8:23 AM
