UTV battery
Discussion in 'Bull Moose Memorial Outdoor Activity Forum' started by Graybeard, Nov 14, 2019.
  1. Graybeard
    Graybeard Member Full Member Thread Starter
    1,698
    634
    Wisconsin
    It seems UTV/ATV batteries are small and overpriced. I wonder why I couldn't replace it with a car battery? I know I'd have to modify the frame and hold down but it might be worth it. I want to use it for plowing and with the current original battery it just doesn't have the cranking power to start the unit in cold weather. The battery is positioned in a terrible location or I'd just use my jump starter but that would be a real pain.
    Wonder if anyone has experience or thoughts with this issue?
  2. Rocking RP
    Rocking RP Member Full Member
    383
    234
    Midland, TX
    Roger
    Thoughts are it shouldn’t be a problem. Just keep the cranking amps close to original. A little higher amp wouldn’t hurt, too high and you could reduce life of starter.
  3. vegas urban lumber
    vegas urban lumber Member Full Member
    1,743
    624
    las vegas
    trev
    off road batteries are typically sealed agm or seal maintenance free, car batteries typically have tops plugs that come off and need refilling, most car batteries don't take the jolting and banging of off road very well.
  4. Brink
    Brink There's nothing to see here Founding Member Full Member
    5,604
    3,989
    North central Putnam county, NY
    Brink
    a starter will only draw a certain number of amps regardless of battery capacity.
  5. Mr. Peet
    Mr. Peet Member Full Member
    3,608
    1,165
    If you don't do the rough riding, an auto battery is fine. For plowing, is it a winch style? What is the draw? Having a secondary battery might be a good idea, to have a larger capacity (wired to maintain proper voltage). Then having a battery maintainer to hook into when your done to build up the 1 or 2 batteries is also a great help.
    I've had good luck with Tru-gel batteries in the sled and bike...
  6. Graybeard
    1,698
    634
    Wisconsin
    It will be a winch type with electric assist moving the plow left and right. Wondering about a battery maintainer plugged in and leaving the UTV outside? Anyone every use one?
  7. Mr. Peet
    3,608
    1,165
    Most of the maintainers have a detachable pig-tail that you can route how you want. Friends I have route the pig-tail to inside the cab area of the UTV. The regulator part can sit inside the cab portion. No cab, build a weather shield box to cover the regulator, pig-tail receptacle and extension cord end. One friend has the maintainer unit in the glove box and just pulls the cord out and plugs in the extension cord under the cover of the cab. Lots of folks don't have it plugged in all the time, but just a few hours before use and a few after use.
  8. Graybeard
    1,698
    634
    Wisconsin
    Here's one that's recommended on the Polaris Ranger 570 user group. http://www.etx30l.com/
    Pricey but the thing is I'm having knee replacement and my wife (75) will have to plow our driveway. No way can I have her come in and say the Polaris won't start. Could be too that this will be the case for two winters as both knees need to be replaced.
    :scare3:
    • Informative Informative x 1
  9. Graybeard
    1,698
    634
    Wisconsin
    Just to wrap it up. I spoke with the Polaris dealer and they have a 20 amp. battery upgrade in stock so I went with them. They'll also add the battery tender and have it all ready to go. Expensieve but sometimes your choices are limited. I used to do everything myself, now it's a happy day if I can pee.
    • Sincere Sincere x 1
  10. Graybeard
    1,698
    634
    Wisconsin
    Afraid my dealer is a bit overwhelmed with work. They forgot the battery and tender. When I called they told me I already had the largest battery and my neighbor, the mechanic would stop on his way home and install the tender. I had it plugged in overnight and it's still not fully charged. Not sure what that means, will have to give Randy (mechanic) a call after the holiday.
Current Time: 8:57 PM
