In my thread Setting Up Shop I showed the very start of my workbench build. It was simply cutting pieces to rough length for the top.
Well, I started 8 days of Staycation yesterday and started in on the workbench build. Figured I'd do a build thread on it. My goal is to have it as close to completion as I can before staycation is over.
Yesterday I made a couple quick Christmas gifts on the lathe - a stopper and an opener - and forgot to get pics before my wife wrapped them. I also prepped the shop for today's work - put things away, emptied the dust collector bin, etc.
Today I started with edge jointing the rough boards and then ripping to about 2 3/4" width. My goal is a 2 1/2" thick top. After ripping to width, the boards got face jointed and then took a run through the planer.
And oriented as it will be for the top. I drew a pair of lines and numbered each board to help with orientating and lining it all up during the glue-ups. I'll be gluing up the top in 6", or less, sections so that I can run each section across the jointer and then plane to thickness before gluing up into a whole top. The top will finish out to about 54" x 30".
This bench is being built from solid Ash. I have a Wilton vise that I previously restored that I will be using on this bench. I am still undecided on whether or not I want to install a tail vise of some sorts. I don't do much hand work, so I'm not sure how much I'd use it. Or if I want a vise handle sticking out that end of the bench, since it'll be oriented at a major walk-through area in my shop.
