I've mentioned here before I want to start learning some flat work, and I also have wanted to make a box for some of my callmaking supplies - so thought I'd put the 2 together. I have a design in mind and some cocobolo I'm thinking of resawing and planing for it, but decided a mockup of the basic dimensions would be wise both to test dimensions to be sure they'll fit my needs and to get a little practice.
I'd originally thought I'd use this opportunity to also learn dovetails, but decided against it after changing the functional design a bit. As you'll see, the model uses mitered joints with strength coming from a couple internal "shelves" that are set in dados.
This isn't the final design but a mockup of the basic shape and dimensions - but I'd appreciate any feedback, comments, or advice on construction. I assume I'll want to add some splines to strengthen the miters, whether across the joint or down it? Planning to use 3/8" thick wood. Thanks for any guidance!
