Frame for Birth Sampler
Posted pictures a couple weeks ago showing the frame profile for the sampler. Mom (Great Grandma) finished the sampler a few weeks ago and has been waiting for me to finish the frame. Got it done and cross stitch installed today. Going to be delivered tomorrow.
This is the general profile I used. The final version is slightly different.
Here is the corner profile on the finished frame.
Low angle shot of the inside surfaces.
Back shot after mounting.
And here it is. Went to a local frame shop to get a piece of glass and asked about options. Showed us some examples of "museum glass" 99% UV resistant, and no glare. Pretty amazing, can't even tell it has glass. That will be the only thing I'll use in the future.
Beautifully done Tim- the profile you put together, the wood coloring and the sampler looks great together.
You might want to consider adding these so this great piece of art work will last for a long, long time for generations to come and appreciate is to use an acid free backing and then seal the back as you don’t want moisture, mites, etc. to get into and damage the art work. You can either buy wide acid free tape and seal the seams (the tape should kiss the partial wood frame and the backing material on center) and make sure they overlap as they intersect or you can buy an acid free Kraft paper, remove the hooks and use a double sided tape and stretch the brown paper to cover the back- leave about 1/8” setback on the flat profile. Use a plastic putty with a flat profile so the acid free Kraft paper will stick and stay flat- make sure it is stretched from the top to the bottom. Then put the eye screws back and the wire back together.
Thanks Arn, hadn't thought about fully sealing the back like that.
Very, very well done! And I agree on the kraft backing.
Next one is going to be gilded?
That is a skill that I always thought would be interesting to learn, but I think if I ever do any it will be on a turned form rather than a frame. I don't mind working on frames, but I do one so seldom that they take 10-20 times as long as they should.
^Tim’s next custom frame one (ahem, subliminal message) will be his perfected “Verdi gris” technique on a past project with some subtle gold gilding highlights that seeps through the Verdi gris in the inside corners or the silhouettes of the rounded profiles.
Love to see you do a small mirror like this for a powder room with a 1” bevel on the mirror that is antiqued.
Now that sound like some fun experimentation! I was doing some cleaning/organizing the other day and came upon the Verdi Gris supplies and thought I should do another couple of projects.
You've got my mind spinning now!
