Hello fellows.I would like to share one more homemade tool.A venner saw made in two different ways.To be honest I thought the Pax venner saw worster than homemade ones
I read this about someone who needs a left hand veneer saw I designed these two.You can use the Kunz replacement blade as a source or yours old saw blade as well.
Someone helped this guy below:
My model works very well.This is a tooth less model and I use in plástic,veneer or vinyl.I have a tooth blade too.
This is my both hands model
Here if you change the screw position you have right,left and straight positions
The handle here is an old hammer handle
The pin locks at right or left hand position
This kind of nut
The pictures are not good but I believe you can understand how I did
This kind of nut
