Keepsake box for my wife
This is actually the first time I've done anything like this, first time I've ever used poly, first time I've ever hinged a box lid, as well as mortised a lock. So for this many firsts I'm pretty stoked with how it turned out.
I've always loved the way that walnut and curly maple look together, and have always had an infatuation with handcut dovetails so when she asked for the box and told me what it was for I knew exactly what I wanted to do.
For the lid, I took the walnut strips and mitered a frame for the outer perimeter, and used a dado stack, with the height set to the thickness of the walnut, and cut the rabbets into the maple. I chiseled away any excess and squared up (to the best of my ability lol) the rabbeted face to the side of the raised center and fit the mitered frame to the side of the raised center. I had a few gaps, so I used some thicker walnut plane shavings I had and filled the gaps.
Then I realized the piece of maple I used didn't quite cover the entire area where the lid should sit so I made another mitered walnut frame for the underside of the lid with just a slight overhang. Then I used the 45 degree chamfer bit on the router table to start the angle of the lid, and adjusted the angle with a hand plane. I recessed the areas for both sides of the hinges and found out the material was too thin and busted a screw through the outer lid, so I switched the hinge to the outside of the lid and ran the screws inward instead to cover the mistake...As they say, the majority of woodworking is finding a way to cover the mistakes lol.
I marked out the mortise for the lock and removed most of the waste with Brad point drill bits on the drill press and cleaned it up with the chisel. The actual locking mechanism when raised was too tall for the thickness of the material of the lid so I filed down the top of the lock arm to a height that would work for the lid and then carefully mortised the area for the locking mechanism to open and close. The key hole was a seperate piece and too long for the width of the box face so I cut it down as well.
The dovetails I cut by hand, and no matter how much I practice I can never seem to get gap free dovetails, so I fixed the gaps by opening up the gaps further and wedge walnut slivers into the gaps in the maple and attempted a faux-double dovetail look that actually surprisingly worked out pretty well.
The base is just edge jointed strips of walnut cause I didnt have any walnut that size that I was willing to run through the planer.
The poly finish turned out much better than I had expected given that it was my first try with it. I just applied a thin base coat with a bristle brush, let it dry overnight then scuffed it up with 320/400 grit and applied a thicker 2nd coat.
My wife loves the box, I think she was kinda surprised at how well it turned out given that I had never attempted anything of this caliber before.
Great writeup! Now you gotta have more than one picture!!
That’s beautiful and the fact that there was so many firsts turns it into stunning in my opinion. :)
  • #12
Thanks for all the positive feedback everyone, it makes our craft all the more rewarding. Here's some more photos of the box.
That is an awesome box! Looks like you have made at least a dozen before this, not like its the first one!! Really like the wood combination, and the stacked look
  • #14
I've made 3 boxes in total, but the other 2 look like a dumpster-fire compared to the way this one turned out. I was very pleased with the end result.
I have made what seems like a million boxes and I was well into my 50th or so box before they looked that good. Jim
  • #16
The first box, if you can call it a box, that I made was an all purpleheart dovetailed box that my wife now keeps some over makeup in. Being the newbie I was at the time I saw that beautiful purple wood and thought I was going to make the most beautiful box out of it. Then reality slapped me with five fingers full of tear-out, gapped dovetails so big you can see through them, dulled chisel after dulled chisel and purple splinters in every finger on my hands. I got so frustrated with that box that I dont believe that box has a truly squared piece of wood to it,, there's no lid, it's not sanded, and there's no finish on it.
So this newest box is a definite far cry from my first attempt at a "box" lol
  • #18
Actually, here's the box in question lol I wasn't joking about not being squared and gapped dovetails big enough to see through lol and for some reason I chose the box faces to be the pins instead of the tails lol
