My journey into stablizing and dying.
jaustin
Thomasville, NC
I am pretty new to stabilizing and thought i would share my experiment with Cactus Juice and Alumilite dye.
going to practice with red
100 drops red
20 drops yellow
32 oz cactus juice.
2 1" thick pieces of Spalted Hackberry
2 1" thick pieces of Spalted HACKBERRY
http://i94.Rule #2/albums/l89/gunracksonline/IMG951892_zpse120a845.jpg
http://i94.Rule #2/albums/l89/gunracksonline/df32ea2f-ba01-4d81-83bd-7e645c3ad2d3_zps890dce43.jpg
  • #2
Been under vacuum for 1 hr still a few bubbles going to let it sit for 30 mins then apply a vacuum again.
Oven is heating up about 200 degrees on thermometer.
wood before
http://i94.Rule #2/albums/l89/gunracksonline/20130608_221638_zps09ea234d.jpg
after removing it from the tank
http://i94.Rule #2/albums/l89/gunracksonline/IMG951893_zps46b8dfca.jpg
started where my finger is pointing.
used about 12 oz of cactus juice.
http://i94.Rule #2/albums/l89/gunracksonline/IMG950421_zpsfea00c16.jpg
Can't wait to see it dry and cleaned up. Good for you for making the effort to do your own.
eventually going to get into pressure casting.
Found a old Binks on Craigslist for $35 cost me $25 for a new seal.
Pot says good to 80psi but testing it at 60psi. I will see how long it will hold.
http://i94.Rule #2/albums/l89/gunracksonline/20130608_230435_zps79e378f4.jpg
Fresh out of the oven.
http://i94.Rule #2/albums/l89/gunracksonline/20130609_000800_zpsb6b9f48d.jpg
cleaned up
http://i94.Rule #2/albums/l89/gunracksonline/20130609_001959_zpseb3d5b60.jpg
http://i94.Rule #2/albums/l89/gunracksonline/20130609_001922_zps6f1fbf2e.jpg
John -Its really pretty damned awesome that you are doing and posting this for us, :thanx2:
That color you just posted may look a little subdued, but when you put an oil on it, it will POP !
Looking forward to the progress pics.
scott
Thanks
Can't cut it tonight had a few beers and won't touch a power tool when drinking.So it will have to wait tomorrow.
  • #10
scott
It does look pink but don't know till you experiment
I finally got back out to the shop today.
Sorry for the big pictures didn't want to resize so that everything can been seen.
The pictures before I split them and after.
Block A
http://i94.Rule #2/albums/l89/gunracksonline/20130609_121445_zpsf170d8b1.jpg
Block B
http://i94.Rule #2/albums/l89/gunracksonline/20130609_121511_zps6e5c033f.jpg
Outsides of both blocks after splitting.
http://i94.Rule #2/albums/l89/gunracksonline/20130609_122738_zps373b0942.jpg
Inside of both blocks
If you look on the ones on the right "B' there is some natural wood color that the stabilizing didn't penetrate to.
http://i94.Rule #2/albums/l89/gunracksonline/20130609_122810_zps783991d2.jpg
And the tank after cleaning it up. Could not get all the dye out of the seams.
Used warm soapy water to clean it with.
http://i94.Rule #2/albums/l89/gunracksonline/20130609_121208_zps60337c82.jpg
Glove there showing son and nephew it expanding when you place a vacuum on the chamber.
  • #12
Quick run thru a buffing wheel. Only polished half of the block.
Tripoli and White Diamond.
http://i94.Rule #2/albums/l89/gunracksonline/20130609_125249_zpsd8faf08b.jpg
  • #13
Finished a set off grips out of it.
http://i94.Rule #2/albums/l89/gunracksonline/20130609_205816_LLS_zps2c2a292b.jpg
http://i94.Rule #2/albums/l89/gunracksonline/20130609_205739_LLS_zps38564a5b.jpg
