Saker chisel sharpening guide.
This is the cheap style of sharpening jig most everyone uses. I have used it for many years but I always felt so so about it. I didn't want to spend the money on one of the big names like Veritas, etc.
This one would always move when you tightened the clamp.
So I thought I would try this Saker brand from Amazon.
Its all anodized alluminum and it has a nice wide roller for stability and it is easy to set up.
So now you can see the 3 different angles on this chisel, it is now square and itll take awhile to get the other edges removed with sharpening. With the sandpaper method I use very little material is removed with each sharpening.
20261102_161955.webp 20261102_161955.webp 20261102_162007.webp 20261102_162019.webp 20261102_162027.webp
It clamps both my Japanese chisels and my narex chisels. These pictured are morticing chisels. I'm sure it will work excellent on my plane blades also.
For the $20 it cost I'm very happy with it.
When im done chopping mortices on the project im working on maybe I'll try and correct the primary level with some coarse paper. I do not have a very good grinder set up to do this so its all by hand.
Looks good. I like stones. I never really liked the consumable aspect of sandpaper. I don’t use it on wood either when I can help it.
You might want some kind of wet grinder. A Tormek or similar. Flat over hollow grinds are so easy to sharpen.
Yeah I get all that. But I'm cheap, I dont want to make the investment in all the stones or a wet grinder. Sandpaper on a piece of glass works great for me. All the grits are in one place and it only takes a few minutes to put an edge back on a chisel while I'm working on a project. And I dont have all the mess of the water. The project I'm working on now has huge mortices in hard wood that takes a lot of heavy blows with a mallet and chisel. I can chop out a mortice and then quickly put an edge back on the mortising chisel. I use a lot of cloth backed paper so it last quite a long time.
