This was a quick build that I did while I was waiting for replacement electrical components for the kitchen hutch build. Start to nearly finished was about 2 days. Then I let it sit for the finish to cure some more. Tonight I installed the hinges and turned and installed the knob. And it's done!
Made of locally grown/harvested/milled Soft Maple. Panel is my first go at veneering anything and is, near as I can tell by comparing it to a known piece in my shop, Waterfall Bubinga. Used a random piece of non-figured veneer, probably some sort of mahogany, to veneer the back side of the panel and make that side look nice too. Plugs are Walnut. Knob was turned from Ebony and fits the piece and looks a lot better on it than any of the manufactured knobs I had in my hardware bins. Finish is Arm-R-Seal in Satin. Is about 30" tall, 15" wide at the top, and 9 1/2" deep at the top. Measurements were all based upon proportions of the veneered panel and the maple I had on hand that I had leftover from the hutch build. For the sake of time, I did not want to have to do any panel glue ups to yield wider pieces, and I was able to achieve that with this piece.
