Ok question I cut this log about 3 years ago and raised it off the ground to dry. Figured it had rotted by now. Found the log to still be good and solid. I cut some off this pass Thanksgiving and sealed the ends and removed the bark. Problem is they seemed to crack from outside in not on the ends. I thought by removing bark wood stop any decay and remove what grubs and bugs were there.
Do I leave the bark on to slow the drying process or remove? Do I need to seal the outsides up or wrap them?
I haven’t seen much curl but they have definitely spalted fairly well.
