Generally speaking, I am considered to be a nice guy.![]()
Dan, I can't believe you made that comment. After all, he's from Texas. ........... NubsThat is nice of you.
That ERC is gorgeous!!!!!Cedar
We brought back a decent Cedar log as well. He has about 20 of these on the ground in a pile. We chose this one due to a good working size to manually load.
It yielded 2 - 3" slabs. 9' long.
View attachment 295568 View attachment 295569 View attachment 295570
Would make an awesome box, or two, as well!I can sed you some Cedar to get you started.![]()
I can't speak from experience, so take my advice ...... I'm on a forum where they have a CSM thread and most there would probably agree you're pushing it on wide boards with only a 60 cc saw. With that said, I have a 66 cc and a 76 cc saw, once I get them running, that I plan on doing the same thing. I'll try to limit my cut to 20" or so. Maybe then I'll be able to salvage those logs I can't load by myself.Last summer I ordered an Alaskan mill from Granberg and have now used it a few times. I learn more each time I use it.
I thought that I would create a thread here to share some of those efforts.
Reading Greg's thread put the idea in my head. https://woodbarter.com/threads/chainsaw-sawmilling.45766/ @woodtickgreg Then going down the rabbit hole on the Tube.
My mill is a 36" Granberg Alaskan Mill. The saw is a Husqvarna 562xp which translates to a 60cc pro saw. I run a 32" bar on it with Granberg milling chains. When not milling the saw wears the factory 20" bar and standard chains.
Most Alaskan mills use the largest saw / bar combination possible. And weigh 70+ pounds fully dressed. My setup is intentionally smaller. I work by myself most of the time and have no desire to sling 70+ lbs of saw & equipment around. This intentionally limited the size of tree that can be milled to a size that I can move around, load, and stack by myself. Max slab width is about 28". The largest log that I've tried so far was the Cedar Elm shown below which was around 22" across. The little 60cc saw handled that just fine.
Thanks for the input, Dan.I can't speak from experience, so take my advice ...... I'm on a forum where they have a CSM thread and most there would probably agree you're pushing it on wide boards with only a 60 cc saw. With that said, I have a 66 cc and a 76 cc saw, once I get them running, that I plan on doing the same thing. I'll try to limit my cut to 20" or so. Maybe then I'll be able to salvage those logs I can't load by myself.
You're not doing it every day and your logs aren't that big. This isn't criticism just what I've gleaned from that site. I don't want you burning up your saw. You're probably doing OK, but just to be safe, maybe consider running a 40:1 mix (must retune carb). That will help keep the internals cool on high load cuts. And another easy to do thing is to leave the saw idle for a minute in between long cuts. This lets the engine dissipate the extra heat in between cuts. I'm not talking about those short boards you cut. Even let it run a minute before shutting it off.
I worked at a mill for a short time and it was always fun at seeing what's inside a log. To be milling, drying and crafting something from the wood yourself is even more satisfying. Have fun.
I'm sorry, I didn't mean to suggest things you knew and were already doing. Looks like you've done your research. I'm guessing there are guys out there that get a CSM and think they can cut everything without consequences. Saw repair is expensive, just ask me. lolThanks for the input, Dan.
The 60cc saw cuts just fine on the 24" or smaller cuts that I have done so far. The concern that only an 80 or 90cc saw can do this is unfounded. As I clearly stated the size was chosen for the weight of the equipment, ease of usage, and material handling (just me, no mechanical lifting equipment)
I do run a 40:1 mix when milling. I have about 10 milling chains and keep a sharp one on at all times. Sharp chains are important. The saw idles after every cut to cool down. The longest cuts that I've done were the Cedar yesterday at about 9'. It was so soft that it cut easily & fast.
It isn't shown in the pictures posted earlier, but there is also a fan blowing across the log while I was milling. This moves the exhaust & sawdust away and the saw sits in its path between cuts to cool off.
View attachment 295580 View attachment 295581
