- #41
Cross Sawmill said:Horsepower IN?? Gallons per Minute?????? Pressure???????? Line Length ??? Motor Speed??????? IF!!! something like this is going to work, ALL this AND other questions have to be addressed.Cross Sawmill said:Bill,aerocustomsexotics said:jimmyjames said:Yep, I have 2 different style valves, I have 3 valves open center with motor spools and also the fitting for power beyond to go ton the 2nd set of valves that are open center with cylinder spools for the cylinders. I still have to get a bunch of fittings etc and I will add a main bypass on the main supply line from the pump, its a bypass valve correct that has a line that goes back to the tank?
When I said control valve should have preset or adjustable relief valve that was a "recommendation" of the type of valve to use-assuming it would need to be purchased new, always better if you have to buy a valve get one with built in relief protection. Motor spool was what I meant when said open center with float feature for motor control. But beings there was not a specific question I was just making some recommendations on things to be mindful of during the setup- design of the system.
Bill
I believe that a hydraulic motor for a band-saw sawmill would need to generate at least 30 horsepower and the bandwheel would need to spin 500 to 1,000 rpm (according to diameter) . That is a "Helluva" hydraulic system!
??????????Steve
I'm going direct drive off of the engine, I'm going from the engine to a jackshaft which has the hydraulic pump on one end of the shaft and a clutch on the other, in the middle is the pulley for the belts from the engine and then belt from the clutch to the drive wheel pulley on the band wheel shaft.
I decided against using hydraulics to run the band since it would take 100+HP to get a hydraulic motor to output 30+HP, the pump and motor would have been too big and too expensive and not worth it
