Finished pulling stitches and epoxying external seams late last week and got the boat outside for a light sanding and for rounding hull bottom-to-side and panels-to-transoms in prep for epoxy and glassing.
Before I do that, though, I need to dry fit the keel (while I have good reference points for the center line) and measure and mark for strakes/runners (to get them lined up with the keel). That meant ripping some African mahogany for those bits (ripped sheer clamps/gunwales while at it). I didn't have 16' pieces of lumber, so will need to scarf pieces together. Futzed around today on jig ideas, will get then scarfed and glued tomorrow.
The one "knock" on this boat design is that many have suffered porpoising. Solutions include wedges on the bottom or adjustable plates on the rear transom that, if dropped slightly below the bottom of the hull, act like trim tabs). My suspicion is that porpoising isn't a design issue, but more likely a result of needing to round over the hull to transom edge so it can be glassed - whereas a sharp edge there is important for correct water flow. I'm planning to build back up to a sharp edge after glassing, but found some old, aluminum manual trim tabs I'll use instead of machining my own plates.
