Box of small bowl blanks
Albert Kiebert
Powhatan Virginia
Albert
SOLD and RECEIVED
PLEASE CLOSE
Here are 5 bowl blanks, various types, sizes on pieces
Ambrosia Maple x2
Red Elm, Curly x 2
Bradford Pear x 1 Pith crack can be filled, has been sealed after taking photo
$30 shipped
I can cut you a slice for your collection off this 6x9” piece. How thick??
Samples finish at 3" wide by 6" long by 1/2" thick. You said off this, no picture shown. I like sample blanks a bit bigger so I can work them to finish size. So 6 & 1/8" long works, 5/8ths thick gives some play to work it and extra packing to protect during shipping. If you rip 2 pieces at 3 & 1/8 wide, I'd share the other with Paul and that leaves 2- 5/8ths pen blanks for your stock. How does that sound? Not sure of the orientation of the block.
Posted photo
I’ll cut these blanks and if you sent enough money to cover a usps padded envelope I’ll ship it out.
Sounds like a very fair offer, Thank you. Only one issue, the wood posted does not match Red elm, Ulmus rubra. I tagged Paul for a second opinion. Maybe I'm not seeing it, but I don't see any of the graining common to elm.
@phinds
@phinds
You won't see the gain by looking at photo posted too much dry diluted yellow glue that I use for sealer on it. Red Elm in my best guess.
@phinds
It COULD be elm, maybe, but I agree w/ Mark. Doesn't look much like it. Can you show the end grain?
Albert,
Wood arrived this morning, very well packed... that is the good part. Had a structure fire-call before getting a good look at it. Down side, it matches 'Flame cherry'. I'd guess by weight and looks, common 'Black cherry'. I did not do a burn test or odor test. Need to get showered first, still have some soot in my system.
Albert,
Mark, hope no one got hurt in the fire. Guess I was way off on identifying this wood. Ironic that you identified as flame cherry and then had to go to a fire...
Think every one is ok. Ya, opened your package and said, "Well, that's not elm, it's flame cherry. "Had to run a few errands before lunch and had tones go off as we got home.
A bit off, I assume maybe fixed it up when cutting blanks? So be it. Bit wiped, good night.
A couple days delayed getting this posted due to illness, but I received my blanks. Look great.
Thanks Albert!
N
Posted by fat thumbs.....isn't there any way to delete a reply???
N
Ya, you hit the edit button and delete everything.
Albert, did a quick follow-up burn and smell test, for sure 'flame cherry' versus red elm. Thought Eric would want to know as well.
Doesn't work. Edit and delete all and save.....it says 'problem, please enter valid message. If hit cancel, back where you started, nothing deleted.
Must have changed during one of the updates. Guess the next best thing is to change it to one of those "cute e-moe-gi's. That way it looks like you knew what you were doing.....?...
