Ever wonder what to do with that box of cutoffs. i just had an idea when looking at the thread “British sports car”. Why not make hardwood building blocks? When I was a child, I spent hours on the floor building castles, forts, houses, towers, etc…. If I could think it, I built it. And I can’t think of a better gift for a child with a growing mind and as a bonus, the junk box gets cleaned out.
For those that remember, blocks were dimensional. For example, two small rectangles equal a square. Two squares equal a bigger rectangle. The thickness of the squares and larger rectangle equal the width of the squares and rectangle. You get the idea. Also be sure pieces are large enough they are not choke hazards.
Cut one rectangular brick and keep handy as your template and you never need to measure again. Use the brick to adjust your saw and every time you cut a shape, it will be the same. Be careful and keep your fingers away from the blade on small pieces with whatever way you clamp what you’re cutting.
