Good data point. As I'd noted, I didn't know how well my resin experience jived with casting wood. Far better to learn from those with real experience.i'm glad i wasn't actually too far off base. i thought i had heard such before
StrangelyFinally, someone making something out of Cholla other than calls and pens. Very nice form.
What did you use to attach the Ebony to the Cholla? ............ Nubs
, many of my adhesives were "unresponsive" due to how cold my shop gets. I finally found a 5-minute JB Weld clear epoxy that would flow (barely), so that's what I used. I do my normal clean/abrade/blow-off cycle on all wood surfaces. All clamped together with moderate pressure. I let it sit for two days, in the shop, to try to ensure a well cured joint, but probably should have popped it into my toaster oven for an hour or so. Hindsight ...
