Way back awhile ago I picked up a MFRB of Ipe from @Bill Hatton just because. Wasn't sure what I was going to do with it, but it looked interesting. Cut a piece a few weeks ago for use on another project that changed directions, and it didn't get used as intended. In cleaning the shop last night I decided to try it on a pen and see what it was like.
While I don't think it'll ever move to the top of my list of fun woods to work, appearance wise I must say it definitely has some promise. Trying to round this stock out was interesting to say the least, and that was with the new carbide turning tool. It lived up to it's reputation of being dense, hard to turn, suspect it would be a little hard on cutting edges on tools, if not using carbide. Once rounded out it turned pretty decent, however it seems to be real directionally preferential. It turns one way real nice, the other it likes to rip and tear grain real easy. Enough so that it was easier to turn up hill the direction it wanted to play, than it was to turn down hill the direction it didn't. Hence the very skinny top end of this pencil, since I discovered it was not an issue with the turning tool, it was in fact a characteristic of this new wood I was playing with, when I was getting down to finishing passes with the skew.
Sanding, it wasn't bad; coarser grits easily moved a lot of wood, finer grits polished it up to shiny rather quickly, suggesting it's a bit oily by nature.
Seems to have decent character to it, I was actually kinda surprised as this was simply a plain old piece of Ipe decking, nothing special about it. It does have decent chatoyance to it as well, so it's kinda interesting in the light, and that's even in my not so brightly lit shop.
Next time... I'll probably knock the corners off the blank on the bandsaw to make rounding the stock out a little easier. And, figure out which way the grain wants to play nice before getting down to finish cuts. But, given this one's appearance, I'm pretty sure there'll be more.
And, in case any of you looks at this pencil and says, "Hmmmm... That squishy part on the bottom looks short!??" Not sure what line I was looking at when I cut the bottom end of that damn blank, but I already had it pressed together when I discovered I'd measured wrong, and it was easier to shorten the squishy, than it was to disassemble and turn it a 1/4" shorter at a quarter after midnight!
