Curly Maple Fishing lures
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #21
Those are looking cool. A countersink or chamfer bit may help with drilling for the eyes.
Try a countersink bit. Just barely have the bit sticking out to keep from walking.
Thanks for the tip.
I Think I’d be fine if I clamped the plug down. I didn’t drill the one hole deep enough and was eye balling it (no pun intended) when I reintroduced the bit.
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #27
FAIL! 5 minute epoxy and a boob with a heat gun
Break out the abernet after it dries and see if it’s salvageable.
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #29
More to this than I thought. Very interesting.
This is for plugs that are going to see salt water. I’m through wiring them on the off chance something decent blunders into one of them. For the stuff I’ll make for local use it’ll just be hook hangers for belly hooks and screw eyes up front and in back
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #31
Some completed plugs. I have no idea how they actually work in the water yet got a couple days off later this week... my tail wraps on the through wired plugs need work.
rocky1
Way North Florida
Rocky
Might want to pick up some Storm SuspenDots for tuning purposes if you don't have any. They allow you to add a little weight anywhere on the lure, adhesive so if it isn't quite right you can peel it off and move it. Dots are 1/8 oz, SuspenStrips are 1/4 oz as best I recall. Adding weight allows you to adjust how the lure sits in the water, it can be used to effect action as well. If you find you need weight, you can keep them, they are pretty durable, or you can peel them off, add lead, and epoxy over it. Kinda fun to play with, see how the weight affects the lure in different places. Starting from scratch like this could be interesting.
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #33
They all have a little junk in the trunk
William Tanner
Bill
I like them and I bet the fish will too. This will move higher up on my priority list. Let us know how you do. I’m thinking of buying the hardware and handing it out as a club challenge.
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #36
Pharmacyguy-Jim
Midland Michigan
Jerry
  • #38
Particularly happy with the dye job on this one. I painted on the dye with the lathe stopped then gave it a rub with DNA with the lathe running, then sanded with abranet 240 until I saw white, then quick rub down with DNA. Drilled eye, weight and hook holes (need some work there) then dipped in Miniwax polycrylic then dipped in minwax professional poly urethane x2 light sanding with a abranet 400 between layers of urethane
