**ENDED** thins for Josh
Tony
Hardwood Enthusiast
Tony
@kazuma78
Josh and I have been talking via PM about Mesquite thins. This is a piece I came up with, it's about 7/16" thick, I can cut it to whatever size you need. The other is a piece of Chechen from Jamie that was too small to use in his cutting board. I can cut it in half where you could have a bookmatched set. What do you think? Tony IMG_20150628_173437_hdr.webp IMG_20150628_173500_hdr.webp IMG_20150628_173512_hdr.webp IMG_20150628_173437_hdr.webp IMG_20150628_173500_hdr.webp IMG_20150628_173512_hdr.webp IMG_20150628_173534_hdr.webp IMG_20150628_173524_hdr.webp
Thanks for posting Tony! I dont think I would end up using those here though. The swirly grain is really cool on the mesquite but I dont think it would show up much in smaller pieces of wood. The Chechen is pretty but I dont think I would end up using it before I left here just because some of the burls I already have cut here will probably take priority. Thank you very much for the thought and posting though Tony! I truly do appreciate it!
No problem Josh, I understand. I will keep an eye out as I go through stuff and check back with you if I come across anything interesting. Tony
