I am definitely interested, I would like to see a pic of it. I wonder if there is a bike shop near you that could box it up and ship it?Since you like old Schwinns, I have a 12 speed you'd love. It's a racer, but I don't know the name of it.
I can check if you'd like. It's been hanging in my garage for 35 years.
Here you can see the fender bracket doesn't line up with the frame bracket. This is often the case when using new modern fenders on an old Schwinn frame.
Not to worry I can just make a spacer, chucked up a piece of aluminum round bar in the ole Southbend. Drilled the center hole and machined the outside to proper diameter.
Aluminum is so fun to work with, machines so easy. Then cut this to length.
Voila! A nice machined spacer that fits perfectly.
The rear rack is part of the install because the rack and fender supports all use the same mounting screws. This is an original old schwinn rack, but it probably came off a 10 speed. I like it because Scwhinn is cast into it and it has the rat trap style keeper. Alluminum alloy so it wont rust.
It's starting to look more like a bike with every piece that's bolted on.
I'm not sure if the seat will stay this low, I'll have to wait until the wheels and tires are on and see how it fits in the final adjustments, might raise it a little.
Raining all day for 2 days! So today was a good time to work on the bike a little more.
Next was the rear fender, all new stainless hardware.
That's actually a painting of my deceased father. I never had a relationship with him as he had his own demons that he never beat. He was a professional clown among other things, his character was Mister Fleas. He made his own costumes. Long story and kind of personal. But that is my father.
That's on of 4 brake shoes, in grease that was more like wax, lol.
Nice clean parts, put them in a bucket of mineral spirits and brushed them off good.
blew them off with compressed air and they look great!
The donor rim is polished, spokes are cleaned and it's almost ready to be laced up. Only thing to do before that is drill out the holes in the rim for the larger spokes and nipples.
Hub is ready to go. Its a Bendix yellow band 2 speed kick back.
I forgot to take pics after I welded it, didn't matter it was my typical ugly welds, lol. Then I ground it smooth and reamed the bore.
See how the jam nut sits down in a feces and has the 2 notches?
The tool fits over the axle.
And down into the recess and engages the notches. Then I can hold the outer cone nut with a week h as I tighten the inner jam nut with the shop made wrench.
