I don't trust anything structural with hot melt glue. If you can reverse what you are turning to turn the waste block off, I'd just glue it directly with regular wood glue. Otherwise I'd make a paper joint with newspaper. Glue on both pieces of wood and sandwich a piece of newspaper between. When you need to remove it, a couple taps on a chisel should separate the joint.
