Melamine Glue Question
Wildthings
ASTROS '23 ALCS CHAMPIONS runnerup
Gulf Coast of Texas
I have a section of double sided melamine that I want to increase the thickness by gluing some 3/4" plywood the bottom of it. What type of glue should I use etc?
Schroedc
Still making sawdust, Maybe make some money....
Rushford MN
Colin
I assume you have the thin laminate right? I'd just use a good contact cement like they use for counter top, Probably want to scuff off any gloss on the back side of the melamine to get good adhesion but should stick pretty well.
They make low voc contact cement too. It just takes a smidgen longer to cure. I think it took 15 to 20 minutes to tack up, but it still had the same strength.
Don Ratcliff
I'm now a Texiian
Ovilla Texas
Don
Could you run a 1.25" screw up through the ply into the melamine along with the glue? That's what I would do
Jerry B
shop dawg
Boulder City, Nevada
Jerry
as stated above, sand/scuff the surface to remove any shiny spots, and then there's a glue made that bonds melamine to anything ....... I'll look it up and post a link for you if you'd like
If you happen to sand all the melamine off (it's only 1/32 thick), then you could just use TiteBond III like you normally wood (might be a better idea for a stronger bond)
gman2431
Douchebag extrodinare
Banned
Michigan
cody
Use a white glue made for melamine and laminate surfaces. When I go back to work Monday I can get ya the name of the stuff we use of it helps.
gman2431
Banned
Michigan
cody
That's it that Jerry has pictured. We laminate all kinds of surfaces together and that stuff is the go to.
