My First Wood Box
Ostie
Dothan, AL
Gregg
Here's my first attempt at a box, and I tried to go all-out and add splines, although they turned out very small and almost unnoticeable. The box is cherry, top is quarter-sawn oak, and the splines are oak. This is with 1 coat of tung oil on it. Plan to do another coat of tung oil and then a coat or 2 of wipe-on poly. If that is a bad idea on the finish, please let me know before I go further; I'm new to finishes. Thanks for looking. DSC_0053.webp DSC_0051.webp DSC_0052.webp
Nice work! Looks great!
Can't comment on the finish, however, as I'm still very much learning finishes and finishing myself.
That looks great Gregg. From the pictures it appears your joints are excellent, and you lid alignment and mating also looks to be very well executed. That's more difficult than it seems. Great job!
Boxes are quite an art form that many take for granted. You've done a fantastic job on this one. Looks fantastic.
And for the record, wipe on poly is great way to get started into finishing. The coats go on so thin, that it's pretty hard to mess it up. You should have great results with that, just make sure to give the tung oil plenty of curing time before applying the wipe on.
That's a great first box Gregg! It's square and aligned (no sarcasm here, it aint so easy as Kevin said) and your wood selection is great. Your on the right track
